Soft Start device for AC units. NOT a capacitor! - Fiberglass RV
Old 09-28-2016, 05:25 PM   #1
Trailer: 1999 Casita 17' SD
Ohio
Hereís review of a device talked about on the Casita forum about small generators like the Honda 2000i running 13,5000 btu AC units.
The reviewer conducts tests using a Honad 2000i, Westinghouse 20001 and the HF Predator 2500 generators and his Mach III 13,5000 AC unit in 100f temperatures in Florida.
A good read for those interested.
Padgett's AC/Generator Shootout 2015 v1.4
Forgot to mention it is $320, cheaper then 2 honda units or a 3000i.
Joe
Old 09-29-2016, 09:53 AM   #2
Trailer: 1993 Bigfoot 17 ftCB / 2011 Toyota Sienna
Micro-Air EasyStart
I've just ordered the EasyStart 366 for my Propane powered Honda EU2000i and my Dometic BriskAire 13.5k BTU rooftop A/C.
The 366 is the board only for a much lower price ($146 + SH) and does the same job as the enclosed 364 but has to be wired and installed with a cover.
Apparently, the manufacturer has tested this device very successfully with my combination of A/C and Genny.
We'll see. Hopefully, I can install it and try it out before I pack it up for the winter.
I'll post results afterwards.
Mike .....>
Michael Pupeza is offline   Reply With Quote
Old 09-29-2016, 10:24 AM   #3
trumpetguy's Avatar
Trailer: Airstream International CCD 28
I added the EasyStart to my Atwood 13500 and not only would it run from a Honda 2000i, it would run on my 2000Watt inverter. The battery drain is 95 AMP hours so even with (4) Trojan T105s the run time was only a couple of hours but that sure makes a difference at a hot rest stop.
2007 Airstream International CCD 28
2016 Dodge Ram Sport 5.7 Hemi 4WD
trumpetguy is offline   Reply With Quote
Old 09-29-2016, 10:32 AM   #4
Ohio
Mike .....>
It also comes without the needed capacitor.
Joe
Old 10-01-2016, 08:35 AM   #5
Ohio
Here's a u-tube video compairing the easy start to the factory hard start and supco hard start.
Joe.
Old 10-05-2016, 02:55 PM   #6
Mike .....>
Where did you find the lower priced item? Have you tried it yet?
Bhamm1 is offline   Reply With Quote
Old 10-05-2016, 03:30 PM   #7
I received and installed the EasyStart!
Bob:
Yes, I got it, installed it, and it works with my propane adapted Honda EU2000i Genny. I'll attach a few pictures, if I can, on how it went together.
My costs, in CDN Dollars were more than US$ because of extra shipping and Customs Clearing costs, but were still well worth it to me.
The pictures show the original wiring with the useless Dometic Hard Start installed, the 366 board mounted on the front plate and then the final wiring with the old hard start removed. It then was screwed back onto the AC. After about 7 start/stops on 'shore' power, I started up the Genny and ran it about 5 times in Econo mode - no problem. Outside temp was mid 70s so this was NOT the real test as it would be in the 90s, but it sounded so quiet starting that I anticipate no problems. Good luck.
Mike .....>
Old 10-05-2016, 04:12 PM   #8
Ohio
Go here
Micro-Air - Products
Then click products > hover over "easy start" click 366 or low cost.
Joe
Old 10-06-2016, 06:35 PM   #9
Ohio
I recieved my start cap today and in 5 minutes I was doing the first of five "learning" starts on commercial power.
Then I brought out my Honda 2000i.
With the AC on high and the trailer 30 amp plug unplugged.
I plugged the trailer plug in and the fan came on and the engine sound only changed very slightly then in 5 seconds the compressor came on and the Honda barley burped, no high speed roar, just a small increase.
I did this several times waiting 3 minutes between starts to allow the AC pressure to bleed down.
Next I tried plugging it in without waiting for the three minute bleed down and the engine sped up but did not roar and go into overload as the Easy Start shut the compressor down and in 3 minutes restarted it all by it's self.
Now it was only 80f here today, not desert heat but still warm.
The easy start does nothing once the AC starts and is running but the engine is running slower. The only reason I can think of since it does not have to speed up so much to start the compressor it's perfectly just putting along??
Just my thought.
Here's the install in my 1999 Dometic Brisk Air 7,180 BTU.
Before and After.
Old 10-12-2016, 12:19 PM   #10
I ordered and received my Control Easy Start 3 Ton from Micro-Air. At my age, and working on the top, it took longer than 15 min., and I did repair holes in my cover, but upon completion it worked as advertised. I still find it hard to believe that I can cool a 25' Bigfoot using my Honda 2000, but it works. This should be in all camper AC's.
Bob Hamm
Old 10-12-2016, 12:35 PM   #11
Ohio
Bob Hamm
Bob
What size AC is in your Big foot?
Joe
Old 10-12-2016, 01:36 PM   #12
According to the book, 11000 BTU. I know all this since, after all, I have owned it about 10 days.
Bob
Old 10-12-2016, 01:40 PM   #13
Ohio
Thanks Bob
The Honda 2000i will start a 13,500 with an easy start too.
Joe
Old 10-12-2016, 04:01 PM   #14
Trailer: 2008 Casita 17 SD
Just finished (or I should say, finally got around to,) installing my new Easy Start. It took a little head scratching to come up with a suitable mounting place since I have the "vertically challenged A/C unit. Finally wound up fabricating a sheet metal mounting plate which I mounted to the side of the air plenum, (after removing the top cover to eyeball the innards to make sure I wasn't going to run a screw into anything that would make me start cussing.) I found a clear spot right next to the capacitor enclosure so it worked out well. Just punched a hole in the side of the cap enclosure and put a rubber grommet in the hole so I could run the Easy Start wiring in and tie it all together.
Soft Floor in Casita Kitchen. Andycamm Problem Solving | Owners Helping Owners 6 05-19-2016 09:55 AM
Need bad capacitor help Myron Leski Problem Solving | Owners Helping Owners 16 03-10-2014 06:00 PM
Bigfoot soft floor scott fraser Problem Solving | Owners Helping Owners 0 07-07-2007 09:32 AM
Soft Shell Jason L. Problem Solving | Owners Helping Owners 18 01-20-2006 09:09 AM
Soft tonneau cover for pickup trucks. Legacy Posts Problem Solving | Owners Helping Owners 0 10-25-2002 09:58 AM
