solar charge controller - Fiberglass RV
Old 08-01-2017, 07:15 PM   #1
Trailer: trillium
I have this charge controller... http://www.hqsolarpower.com/v/vspfil...CTRL-30LCD.pdf
Interesting thing is when I disconnect the panels (switch on the pos wire), I get a reading at the controllers panel terminals of 1.7v
Can anyone explain this? It's showing no amps delivered, as it should, but where is the 1.7 volts coming from? The controller?
Sparky0 is offline   Reply With Quote
Old 08-01-2017, 10:44 PM   #2
The voltage is coming from the house battery. If were able to look at where the wire goes into the panel you'd find a diode. Solar panels without diodes will run the battery down at night. A diode in one of the lines (Kirchoff's law indicate it doesn't matter which line as long as it'f point in the right direction) will stop the two way street to and from a solar panel.
Old 08-02-2017, 12:35 AM   #3
Trailer: trillium
Yes, I've heard of that. How does the voltage run back to the panel with the positive panel wire disconnected?
Old 08-02-2017, 12:44 AM   #4
Trailer: trillium
wait. I get it. the voltage will still show across the controller terminals even if the panel is isolated.
Old 08-03-2017, 03:41 AM   #5
Trailer: Currently shopping
Because a voltage shows does not mean current is flowing.
J Ron is offline   Reply With Quote
Old 08-03-2017, 07:58 AM   #6
Trailer: trillium
a little disappointing as this controller is supposed to have "night time reverse charge protection"
Old 08-03-2017, 08:27 AM   #7
Most solar panels have built in blocking diodes.
Old 08-03-2017, 08:38 AM   #8
Trailer: trillium
This is true, I think I have a non-issue here. Thanks for all your replies.
Old 08-04-2017, 09:30 AM   #9
Trailer: trillium
got a response from the manufacturer.
"The controller does have protection against back feeding, as for the voltage at the panels terminals that is normal there will be surface voltage at the screws but no current. "
Old 08-05-2017, 08:12 AM   #10
Snoopwagon's Avatar
Capacitors in controller sir!
Snoopwagon is offline   Reply With Quote
Old 08-05-2017, 08:38 AM   #11
Trailer: trillium
Of course. I hadn't thought of the capacitors.
Thank you
solar
For Sale: Brand New Coleman 7 Amp Solar Charge Controller Clayton Parts: Buy | Sell | Trade 6 01-19-2015 03:26 PM
Solar Charge Controller clyle Electrical | Charging, Systems, Solar and Generators 21 09-05-2014 08:13 AM
Solar Charge Controller Installation kevin61 Modifications, Alterations and Updates 3 02-22-2009 09:20 AM
Solar charge controller yvonne Care and Feeding of Molded Fiberglass Trailers 24 06-26-2008 05:46 AM
Fluid, Battery Levels & Solar Charge Controller? peterh Electrical | Charging, Systems, Solar and Generators 9 04-27-2007 04:45 PM
