Solar Charger - Fiberglass RV
Old 01-04-2013, 08:48 AM   #1
Chris Jones's Avatar
Trailer: U-Haul
Solar Charger
I have a U Haul CT 13 and I am not sure if the Solar Charger is working. I know it can be tested, but how? This is the last wild in my CT I have everything else working. Any info on these would help me out because I have never used anything like this. Thanks
Chris Jones is offline   Reply With Quote
Old 01-04-2013, 08:50 AM   #2
cpaharley2008's Avatar
I'd unplug the battery and the electric to the trailer and put my meter to the leads to see if any current is flowing from the solar panel.
Old 01-04-2013, 08:57 AM   #3
Trailer: U-Haul
So this thing should make power without a load? I'll give it a look as soon as I can find my meter. Thanks for the quick answer.
Old 01-04-2013, 09:00 AM   #4
Yes it is always charging if subject to light, the controller regulates the output but it is always working in the daytime. If you know where the controller is you can test it there also.
Old 01-04-2013, 10:04 AM   #5
Trailer: U-Haul
Well it has power coming to it and from it to the batterie box wires. But it does not put out enough to run any of the inside lights. I will put a batterie in there and see how it maintains the state of charge over time.
Thank you so much for the help.
Old 01-04-2013, 10:16 AM   #6
Thomas G.'s Avatar
Trailer: For Sale Or Rent
Rooms to Let 50 Cents
Chris, I found that my controller was bad and that the panel itself hardly put out anything.
To test the solar panel, disconnect the wires from the panel to the controller mounted on the side of the battery box. Attach an ammeter lead to each wire end while in full sun. That panel is about 5 watts, so you should get about 0.4 amps or so.
I replaced my panel with a 60 watt panel, which will do some serious charging. The original was only designed to prevent the battery from going stone dead when the trailer sat for a long time.
This place has pretty good prices on solar panels and controllers.
12 Volt Solar Panels
Old 01-04-2013, 10:17 AM   #7
May only be a 15 watt battery maintainer panel. Pictures would help.
Old 01-04-2013, 10:57 AM   #8
Trailer: U-Haul
That's the controller. It clicks when I turn on lights without the batterie hooked up. Might be why it will not run any of the inside lights without a batterie hooked up because it wasn't designed as a stand alone unit. But if the sun is out I won't need lights on the inside anyway.
Old 01-04-2013, 11:22 AM   #9
Chris I doubt if it was originally set up to run anything directly off of it. Solar panels are most often set up to recharge the battery with the lights running off the battery not directly from the panel.
I seem to recall though that original reading here once that the solar panels on the old U-hauls were actually very small 3 watt?? & not really meant to fully recharge the battery - only meant to avoid battery sulfation while the trailers sat at the rental lot.
If it is a 15 watt though it should be able to recharging the battery in full sun in the course of a day with no load on the battery or at least my old 15 watt panel did.
Old 01-04-2013, 11:50 AM   #10
Thomas G.'s Avatar
It is way less than 15 watts. It is an amorphous cell which only produce about 5 watts per square foot when new.
Old 01-04-2013, 03:29 PM   #11
mmeyer's Avatar
Trailer: U-Haul VT
Indiana
I looked at the one I took off the VT the model /serial number starts with a 84 and ends with -15 which would likely indicate built in 1984 and 15 watts. CT 's may be different.
Michael J
mmeyer is offline   Reply With Quote
Old 01-04-2013, 03:34 PM   #12
Thomas G.'s Avatar
Michael J
Dunno. I know that when I tested the output of mine it was only a watt or two after 27 years.
Old 01-04-2013, 04:08 PM   #13
mmeyer's Avatar
Trailer: U-Haul VT
Indiana
When I feel better I will dig out my decade resistor box and do some measurements, I know it will charge 10 ah 12v gel cells.
Old 01-04-2013, 04:23 PM   #14
Thomas G.'s Avatar
Here is a video that shows how to measure solar panel output.
solar
Solar Trickle Charger & Dead Battery V'sGlassSleeper Problem Solving | Owners Helping Owners 11 03-19-2010 07:29 PM
Solar Panel Trickle Charger? Steve Dunkel General Chat 17 02-21-2010 12:42 PM
Solar Charger and Panels Frederick L. Simson Modifications, Alterations and Updates 109 08-11-2008 10:41 PM
Solar Powered Battery Charger Rich S Electrical | Charging, Systems, Solar and Generators 6 10-17-2006 09:19 AM
Solar charger questions Steve Rosenberg Care and Feeding of Molded Fiberglass Trailers 17 12-01-2005 01:00 AM
