Solar Panels - Fiberglass RV
Old 06-02-2007, 08:36 AM   #1
Barbara Gardin's Avatar
We have purchased the standard 3 panels 15 watts each. What we need are ideas for an easily portable (foldable) stand. What suggestions do you have?
Barbara Gardin is offline   Reply With Quote
Old 06-02-2007, 09:11 AM   #2
Trailer: Fiber Stream
Talking
I was initially concerned about a stand for my panels. I figured that I wanted to begin using my panels right away, so I used the stand that came with the Harbor Freight panels I bought. I have since grown accustomed to it, and do not plan to change anytime soon. I was cautioned about vulnerability of an adjustable angle stand to wind effects. Mine sets the panels at a 30* angle, and is surprisingly stable, even in strong wind.
I can pick up and re-orient the panels and stand to the sun as a unit, if I face the panels and grab hold of both sides (panels and triangle frames).
Old 06-02-2007, 09:36 AM   #3
Bigfoot Mike's Avatar
Trailer: Bigfoot 25 ft
I really like what Fred has done.
Just to give you additional ideas, here are some additional solutions others have done.
Front and Back
Folded for storage
On the left NavBar, click Solar to see the full article.
Old 06-02-2007, 10:46 AM   #4
Trailer: Trails West Campster
Post
Hi Barbara,
I just put my solar panels on the roof of my trails west campster. I used mounting brackets I purchased from AM solar. I learned from their web site that on smooth unpainted fiberglass you can mount the brackets with tape that is "stronger than a weld". We shall see...... but I do live in the Sierras and drove it a couple of hours this week down some very bumpy roads, and so far so good.
If I figure out how, maybe I can post a picture. Those panels were heavy and I didn't want to lug them in and out of the trailer. I am really glad they are on the roof!
kfletcher is offline   Reply With Quote
Old 06-02-2007, 10:55 AM   #5
Hi Barbara,
Here is their website: AM Solar
Old 06-02-2007, 01:49 PM   #6
peterh's Avatar
I bought one 50w Siemens panel that measures about 48"x13" that I'll be mounting flat on my roof. I'm hoping that'll meet out 12v requirements . . . but when I install my solar system I'll keep in mind that I may want to add an external connector for a second, relocatable panel later on if the fixed 50w doesn't cut it.
Old 06-02-2007, 05:36 PM   #7
Thanks to everyone for the ideas. We have decided to go with a version of Frederick's stand. As a matter of fact it is about 3/4 finished. We are using some on hand materials so it is not identical but will certainly do the job. Thanks
Old 06-02-2007, 09:30 PM   #8
[quote]Hi Barbara,
Attachment 8088
After looking at AM solar's web site, I can see why they didn't go anyplace. The "tape" is 3M VHB (Very High Bonding). Boeing puts airplanes together using that stuff. Warning the only way to detatch anything mounted with VHB is cut it off. That sounds worse than it actually is, dental floss will work, or piano wire to cut throught the VHB material.
Thanks for posting this, I hand forgotten about VHB.
solar, solar power
Solar Panels For My Home D Tharp General Chat 3 04-25-2010 01:15 PM
Chinese Solar Panels Lisa H. Care and Feeding of Molded Fiberglass Trailers 10 05-31-2009 12:05 AM
Solar Charger and Panels Frederick L. Simson Modifications, Alterations and Updates 109 08-11-2008 10:41 PM
Solar panels on eBay peterh Care and Feeding of Molded Fiberglass Trailers 8 08-07-2008 07:43 PM
Solar Panels Legacy Posts Electrical | Charging, Systems, Solar and Generators 13 04-24-2003 09:09 AM
