Some Basic Questions Re Solar - Page 3 - Fiberglass RV
Old 06-12-2019, 04:34 PM   #29
Trailer: ParkLiner
Virginia
100 watts may not be enough, so go with something between 160 w and 200 w. If mounting on the roof, make sure it will fit before buying the panel(s). Flexible panels are more expensive but much easier to mount.
I just replaced the 100 w flexible panel on my roof, and a Renogy panel wouldn't fit, so I had to go with a different vendor. I have mine wired so I always have the 100 w roof panel, but can add a 2nd 100 w portable panel that can be up to 10' from trailer.
Huck is offline   Reply With Quote
Old 06-12-2019, 04:56 PM   #30
Jim Bennett's Avatar
Trailer: 2017 Escape 5.0 TA
I put four semi-flexible 60W panels on my roof and only in poor conditions (rain, shade, etc) have they never fully charged my batteries in good time every day. I love that they are not even noticeable unless you look from above. Over two years of use and still working fantastic.
2017 Escape 5.0 TA
2009 Escape 19 (previous)
Old 06-12-2019, 07:46 PM   #31
Jane P.'s Avatar
Trailer: Bigfoot 19 ft
Originally Posted by Raspy View Post
That sounds like normal apartment living and not camping. I enjoy actually cooking much more when out camping. Or throwing a fine sandwich together with no appliances necessary. Then there are the breakfasts at small Southern diners, the Texas Barbecue and the Mexican restaurants for lunch. Every morning the coffee pot gets fired up as I survey the situation. A big bowl of morning cereal often hits the spot, for ease, and for a contemplative moment at the dinette window. Interrupted only by a penetrating stare from Gogo to either get a cookie or be let out. The generator would be an appalling intrusion.
Ummm ... between noisy generator and cooking stories, this thread is heading off the grid.
Last year, I bought a stovetop pressure cooker, which has replaced the microwave for most dishes. Unfortunately, cleaning all the pots affects fresh water usage.
Not everyone goes camping for pleasure. I camp on private training grounds, where I work my dogs rain or shine. Particularly during the winter, I return after dark and before I begin preparing food, I first must towel off, air & feed my dogs. So, if running the generator will allow me to eat a hot meal and retire at a decent hour, that works for me.
Having said that I am usually camping with people who face the same situation. So there will be a lot of generators going. I purposely park as far away as possible to mitigate noise pollution. But once again, these are private grounds.
The reason for my ceiling fan is that I want to cool off the cabin on warm days in lieu of an AC (which, BTW, I never use outside of my driveway) I suppose that if we’re caught in a major heat wave, we’d probably pic up sticks and either move to a hotel or return home.
I suppose I use more power in the Winter. But until now, I haven’t needed to think about it.
At this point, I’d like to install a robust solar system which will meet my present and future needs.
'92 Bigfoot 19' | '07 Chevy Tahoe
Jane P. is offline   Reply With Quote
Old 06-12-2019, 08:48 PM   #32
Civilguy's Avatar
Puget Sound, WA
Originally Posted by Jane P. View Post
I believe that I initially need to determine my energy requirements. And i’d appreciate some suggestions on how I can go about this.
Jane, You already, sort of, know what your consumption is. If your batteries are discharged in a couple of days, with careful use, for instance, that is your consumption.
Jane,
I'll try to sketch this with some basic arithmetic. If someone sees a significant error here, I trust they will chime in to help us out.
If you have two 100 amp batteries, then you have about 2 batteries x 100 amp-hours x 0.5 (50% rule) = 100 amp-hours of usable storage capacity in your batteries. This is based on using the 50% rule for usable storage capacity in flooded batteries.
One of the older Fantastic Fans I looked into a few years ago drew about 15.5 / 23.3 / 33.8 watts at low / medium / high speed. If you ran this fan for ten hours at low speed it would be a fairly substantial draw on your storage as follows.
15.5 watts / 12 volts = 1.3 amps.
1.3 amps x 10 hours = 13 amp-hours.
100 amp-hours capacity / 13 amp-hours usage per day = about 7.7 days of potential usage based on your available storage capacity.
This the energy that you would need to replace, based on using just the fan.
As this is quite a bit of energy, you might look into a "Caframo Bora" or a "Hella" marine fans which respectively only draw about 4.0 and 6.5 watts. Newer roof fans with more speeds do offer lower speeds with lower current draws, so now you can evaluate your fan's energy usage if you have the manufacturer's data. The CPAP would be done the same way. Convert between amps and watts, and then multiply times the hours it's used.
We boondocked at Kalaloch for a week in mixed cloudy/ sunny/ rainy Pacific Northwest coastal weather around Memorial Day. We have a 160-watt rooftop panel on our Escape.
As we have long hours of daylight locally this time of year, one might expect to get as much as 160 watts / 12 volts x 0.5 (50% efficiency factor) x 16 hours daylight = about 107 amp-hours.
In reality we saw our batteries display as low as 12.1 volts and 52% due to cloudy weather, and as high as 12.8 volts and 88%. I wasn't rigorous on watching the maximums, but those are the lowest and highest figures I jotted down.
I think our usage was fairly moderate; it included LED lighting, some ceiling fan use, some furnace fan use, the refrigerator controls, charging a computer and phones, and pumping about 10 gallons of water each day.
I always figured I could resort to charging the battery through the 7-pin connector, but looking at Raspy's post about his Yellowstone experience makes me second guess that. Maybe I need "stealth" battery cables - ?
~ "This post is a natural product. Slight variations in spelling and grammar enhance its individual character and beauty and are in no way to be considered flaws or defects." ~
Old 06-13-2019, 08:09 AM   #33
South Carolina
Wired in parallel They’re 12 volt batteries.
in that case they're connecting in parallel. the only issue that i'm aware of is that this wiring really works best with 2 "identical" (age, capacity, etc) batteries. if they are different the older battery will draw down the newer to make a match of those electrons. since you really don't have a choice of how to wire them to produce the needed 12v when installing the batteries just be aware that you might not be doubling the capacity of your system in this case. i'd use what you have until time takes over and both batteries need replacing be sure to buy twins.
my system has two 6v agm golf cart batteries (225 amp hours) and solar charging is provided by one 100w panel on the roof which charges all the time. another panel mounted on the truck's topper roof and can be relocated to find some sun if the trailer's in the shade. i recently made a four month road trip west and made no real effort to conserve those precious electrons. my victron meter never showed less than 90% charged even during a month of boondocking in the arizona desert. my loads on the 12v system are moderate, led lights, minimal television, nearly constant radio and charging all my electronic devices (computer, cameras, phone, etc). i do not have a furnace (i use a wave3 heater which is propane powered) nor any medical devices that require power. for a failsafe backup i have a honda 2000i mounted permanently over the propane tanks and wired directly to the trailer's converter. all this may be considered excessive by some but, i tend to take long trips and would rather not be fretting about power to make me comfortable.
p@
patrick crawford is offline   Reply With Quote
Old 06-13-2019, 04:11 PM   #34
Jane P.'s Avatar
Originally Posted by Jim Bennett View Post
Jim, I never tire of seeing this picture.
For me, this is a process. My initial goal is to figure out my needs. Then I can think about the system hardware.
Old 06-13-2019, 04:17 PM   #35
Thanks.
That is a good approach. I figured out my wants and then struggled to make my needs near fit.
We do use:
-hairdryer for wife
-hair trimmer for me
-occasional tools
-tv, computer
-small vacuum
-a few other things at times
-and best of all, a two slice toaster. Man, having good toast as opposed to the dried stuff the stovetop maker does is great.
2017 Escape 5.0 TA
Old 06-13-2019, 05:01 PM   #36
Civilguy's Avatar
Puget Sound, WA
Okay Jim. I can handle the awesome cargo box. I can handle the custom cabinetry.
Okay, I'm happy for you. Really. I am.
But, toast from an electric toaster ! ? !
That's enough; now you are just being completely obnoxious!
Old 06-13-2019, 05:32 PM   #37
OCJohn's Avatar
Trailer: Hymer
Jim – have you noticed any heat related issues with the panels stuck to the roof? I really like your installation. It's about the only fixed mount method I can use with the pop-top on our rig. Just curious if after two years of observation there's anything you'd do differently...
OCJohn is offline   Reply With Quote
Old 06-13-2019, 05:37 PM   #38
Hey, give me a break, I can be tactful just as much as obnoxious.
Nope, no problems at all. I watched them quite closely down in Mexico earlier this year and there has been no affect in the heat. The panels are only slightly warmer than the fibreglass beside them. Lensun told me they would be just fine and in just over 2 years they have been. Still watching though.
2017 Escape 5.0 TA
Old 06-13-2019, 06:09 PM   #39
OCJohn's Avatar
Trailer: Hymer
Thanks. Do you know of any significant differences between Lensun and Richsolar? The dimensions of their 80w panels are a little better suited to my application.
Old 06-13-2019, 06:56 PM   #40
Raspy's Avatar
Trailer: 2015 Oliver 23, Black Series HQ19
Smith Valley, Nevada
Exactly!
Jim, you really know how to "camp".
Wind bag on the internet
Old 06-15-2019, 04:41 PM   #41
Jane P.'s Avatar
Worth the price of starting the thread!
Old 06-15-2019, 04:51 PM   #42
Jane P.'s Avatar
[QUOTE=Jim Bennett;745316]Hey, give me a break, I can be tactful just as much as obnoxious.
Jim, you are a true gentleman and sweetheart - as long as you're not discussing generators.
Here is a suggestion: Monitor the situation to prevent dryness. I wouldn't want you to strain your solar grid over a couple of slices of toast.
solar
questions, questions, questions cathybr Problem Solving | Owners Helping Owners 4 06-22-2017 10:47 PM
Basic Wiring Questions for PD4045 Converter/Charger Ryan P R Electrical | Charging, Systems, Solar and Generators 11 10-03-2012 03:30 PM
Basic questions ;electrical from a new owner Kent I Electrical | Charging, Systems, Solar and Generators 11 12-07-2010 08:57 AM
Basic Camper Towing Questions Jason Rutten Towing, Hitching, Axles and Running Gear 8 03-06-2010 07:00 AM
EXTREMELY BASIC question General Chat 0 01-01-1970 12:00 AM
