switch incandescent to LED - Fiberglass RV
Old 06-19-2011, 07:18 PM   #1
Trailer: 73 Boler 13 ft
Simple question: are there LED light fixtures to replace our incandescent ceiling fixtures, eg in a Boler 1700, to save on battery juice when off power. Is the wiring adequate? It would have to be exactly the same size, to fit in the ensolite opening, I guess. I haven't seen any, but then don't have many RV stores around here. Thanks!
Peggy is offline   Reply With Quote
Old 06-19-2011, 07:22 PM   #2
Yep there are Peggy. Check out Super Bright LEDs from this Helpful-Links page: http://www.fiberglassrv.com/resource...n=fiberglassrv
This is probably a better link for your needs: http://www.superbrightleds.com/cgi-b...MR16_specs.htm
Old 06-19-2011, 08:10 PM   #3
I checked out that link....so we are changing the bulb only, not the fixture, is that right?
Old 06-19-2011, 08:18 PM   #4
You can just change the bulb, but unless you're a purist you may find it cheaper to change the fixture too. The bulbs aren't inexpensive.
On edit: these are neato: http://www.ledtrailerlights.com/rv/RV-led.htm
Old 06-19-2011, 09:52 PM   #5
Now if only I had some idea of how many lumens my existing single and double interior incandescent fixtures put out....
Just answered my own question! The common 1156 series bulb often used in trailer incandescent fixtures puts out about 400 lumens per bulb (402 if we wanna be precise!) so the 252 lumens per unit for the LED ones will NOT be as bright. However, it will be a different "color" of light and may actually appear as bright. The 1156 uses 27 watts of power each.
(Your experience may vary)
On the other hand 1141 series bulbs are also commonly used in RV lighting fixtures - maybe more often than 1156's! If you have a series 1141 bulb, their rated output is 264 lumens, quite comparable to the LED's 252 lumens. The 1141 uses 18 watts of power, while the LED seems to use 2.6 watts per unit if I am reading the details correctly on the site Donna provided.
Old 06-19-2011, 09:59 PM   #6
Speaking of LED lights, I just got a flyer from Camping World and they now carrying LED light fixtures for RVs. The one thing they don't say is how much current they draw. I plan on visiting Camping World soon and see if I can find out. I think it would be great to replace all of my indoor lighting with LEDs.
Old 06-19-2011, 10:00 PM   #7
Trailer: 1984 Scamp 13'
Maryland
I bought a set of LED bulbs that were meant for trailer tail/brake lights. I decided that they weren't bright enough, so I tried them inside instead. They work great! Not only arethey nice and white, but they use only about 1/12 of the wattage. This is good for me, since the 12v in my Scamp runs on a jump pack.
-Jesse
Old 06-19-2011, 10:05 PM   #8
This is what I used to replace my 1141 bulbs in my Scamp and they seem to be just as bright.
LEDTrailerLights.com - RV LED interior ceiling light 1141 1156 1003 warm white
Bill K
Old 06-19-2011, 10:16 PM   #9
Trailer: Fiber Stream
I was in my local Camping World store and saw their new LED bulbs on display. They have the 1141/1156 equivalents, for on/off. I have 2 fixtures that use 1157 bulbs for hi/lo/off, one in the kitchen and one in the bathroom, which I like to use on the lo setting for those middle of the night potty times. They don't have any 1157 equivalent bulbs for those fixtures.
Old 06-19-2011, 10:19 PM   #10
The stores might not have caught up with the web site. LED Replacement Light Fixtures - Product - Camping World
Old 06-19-2011, 10:35 PM   #11
Yowza! Quite the price difference between Camping World and the site Donna quoted! $39.95 at one and $56.99 at Camping World!
Old 06-19-2011, 11:03 PM   #12
Roger C H's Avatar
Wow! I thought the $20 Tork Lift Central in Kent asked was expensive! Plus they had some that featured a flat section which pointed all the LEDs in one direction, presumbably out.
Old 06-19-2011, 11:15 PM   #13
Looks like the same unites doesn't it.?
Old 06-20-2011, 02:30 AM   #14
Matt in SV's Avatar
I went with a flat 36 LED array (6x6) and secured it flat against the lamp reflector. It shipped with double sided adhesive tape, but I used RTV instead to make sure it doesn't fall off on a hot day.
Regards,
Matt
Planning our next Escape!
Group Buy of LEDs to replace incandescent bulbs DirtDawg General Chat 30 03-21-2011 01:04 PM
LED trailer lights / Non LED lights on tow vehicle Kevin K General Chat 20 11-24-2010 11:05 AM
Breakaway Switch Lawrence W Problem Solving | Owners Helping Owners 10 10-03-2010 01:35 PM
New exterior light installed Want to switch to LED jimtesla Care and Feeding of Molded Fiberglass Trailers 2 06-22-2010 04:35 PM
battery switch Ron Davis Problem Solving | Owners Helping Owners 3 06-26-2007 08:50 PM
