Tapping into DC - Fiberglass RV
Old 09-15-2019, 11:18 AM   #1
Trailer: 17' Casita Spirit Delux
Delaware
Tapping into DC
I have ordered a 12vdc cigarette lighter style electrical connector with outlets to charge phone/tablet devices and a DC battery monitor. I am going to install this in my 17 foot Casita. Will someone tell me the best location to tap pwer from the Casita electrical system? My initial thinking is to attach the negative and and positive leads to the input to the converter from the battery. Is there any issue with using this connection location?
(Electrically). The battery compartment is very tight and I would prefer to avoid adding anything to it.
ccornell is offline   Reply With Quote
Old 09-15-2019, 11:28 AM   #2
Jim Bennett's Avatar
Tying into the coveter and fusing the feed would work fine.
2017 Escape 5.0 TA
2009 Escape 19 (previous)
Old 09-16-2019, 09:56 AM   #3
Not sure if it's relevant but on my Bigfoot I installed the 'cigarette lighter outlet' on the kick panel under the seat in the dinette. It doesn't get wet, it has a plastac cap so small fingers won't insert things in there and it's out of sight. Because I'm a little OCD anyway I changed out one of the 110V receptacles with one that included two USB plug ins. Works when I've got shore power.
burrorojo is offline   Reply With Quote
Old 09-16-2019, 10:06 AM   #4
Trailer: Trail Cruiser
Any connection down stream of your battery but before it connects to anything else should work fine. In-line fuse recommended.
Tapping into DC ccornell Electrical | Charging, Systems, Solar and Generators 2 09-15-2019 11:24 AM
12v accessories flicker when tapping power converter. How to bypass? K_rex Electrical | Charging, Systems, Solar and Generators 26 11-10-2017 10:16 AM
Tapping into the 12V DC Power donalie Problem Solving | Owners Helping Owners 1 05-11-2009 10:07 PM
Running the battery into oblivion Gina D. Care and Feeding of Molded Fiberglass Trailers 11 12-02-2005 02:00 PM
How to dump into (and out of) blue tote tank? Legacy Posts Care and Feeding of Molded Fiberglass Trailers 14 04-30-2003 03:05 PM
» Trailer Showcase
TED
Spanke
1979 Biggar
Mak
