Technical A/C wiring question - Page 2 - Fiberglass RV
Old 09-26-2012, 09:03 AM   #15
Jon Vermilye's Avatar
Trailer: 2017 Escape 21
Oswego, NY
The easiest solution is to be sure the converter is on its own breaker & shutting it off when running the AC. I'd be concerned about the starting surge, which tends to be the biggest problem with running ACs on a generator. The ratings on most generators are peak. For example, the Honda 2000 is called a 2K generator, but actual long term rating is 1600 watts.
In addition, as you gain altitude it takes a larger generator to run the AC. What works at sea level may not do the trick at 5,000 ft...
simple wiring question KarenW Problem Solving | Owners Helping Owners 10 08-02-2016 09:58 PM
12v wiring question freddo411 Electrical | Charging, Systems, Solar and Generators 5 07-02-2012 10:25 AM
Wiring electrical question slbran Care and Feeding of Molded Fiberglass Trailers 16 01-19-2012 09:41 AM
Switch wiring question Lawrence W Electrical | Charging, Systems, Solar and Generators 11 09-12-2011 10:48 AM
