Testing electrical system - Fiberglass RV
Old 07-01-2013, 06:47 PM   #1
courtney's Avatar
Trailer: 1982 13ft Scamp purchased on May 2nd
Okay, I've been doing tons of cosmetic work on the '82 Scamp and am somewhat ashamed to admit we haven't checked out all things electrical yet. The trailer lights worked; we were sure to check that before we drove her home. So, do I just plug it in and see if things turn on? Just don't want anything to catch on fire or anything What steps do I need to take?
courtney is offline   Reply With Quote
Old 07-01-2013, 07:42 PM   #2
Trailer: '77 Scamp
What items do you have in the Scamp that are AC and what are DC? I know you checked the fridge out. Did that work? What do you intend to add?
Otters is offline   Reply With Quote
Old 07-02-2013, 05:21 AM   #3
courtney's Avatar
Only thing I have at all are the two side lights.
Old 07-02-2013, 05:23 AM   #4
courtney's Avatar
Plan on adding additional lights and Fantastic Fan.
Old 07-02-2013, 06:56 AM   #5
tractors1's Avatar
Trailer: Escape 21 - Felicity
I'd buy spare fuses, check any breakers present, and go for it - plugging in makes for much less work than futzing with very long leads on a voltmeter.
Charlie Y
Charlie Y
Old 07-02-2013, 08:54 AM   #6
If all you have is two interior side lights then both should be 12v & run off the battery. If your battery is charged up then just turn them on & take it from there. If they don't work try checking the bulbs first.
Old 07-02-2013, 09:46 AM   #7
courtney's Avatar
So, we don't have a battery. Side lights only run on battery?
Old 07-02-2013, 10:06 AM   #8
Not necessarily all depends on what other equipment you have in the trailer and what a previous owner may have done to it in regards to electrical.
Hard to say without knowing what equipment and types of lights you actually have. If you have a convertor you should be able to plug in your 30 amp (or you may have 15 amp only) and the 12 volt lights should still work (but then again it comes done to what has or hasnt been done to the trailer over the years & if its been changed so that the two systems are independent). If no convertor then perhaps its all been changed to power only. In which case you will need to plug it in to get the lights to work.
Old 07-02-2013, 11:21 AM   #9
David Tilston's Avatar
Your trailer may draw it's power from the tow vehicle.
Old 07-02-2013, 11:55 AM   #10
If that's the case then the OP would indeed need a battery.
But with the limited info given it really is hard to say but as they are questioning if they should plug it in I'm assuming something in the trailer runs on 15amp or 30 amp as it probable wouldnt have an electrical cord if it didnt. Perhaps the OP could advise what they have other than just the 2 lights mentioned. Water pump? Fridge? Convertor? Or then again perhaps I missed a post outlining all that.
Old 07-02-2013, 01:03 PM   #11
Trailer: '77 Scamp
Can you take pics of what you have. Do you possibly have wiring for battery, but battery just isn't currently installed?
Look under the sink. Do you see a small electrical box? If so, there should be a large wire that runs to the AC plug that plugs into shorepower. Also, perhaps an AC plug next to it, where the frige plugs into. Plug into shorepower and use a volt meter to test all the electrical. Its a start anyway.
Old 07-03-2013, 06:23 AM   #12
courtney's Avatar
Yes, there is wiring for a battery and a fuse box under the sink. Most interested in checking shore power safely.
Scamp electrical system Barbara Dill Problem Solving | Owners Helping Owners 4 09-02-2011 06:17 PM
RV Electrical system by GoodSam Club Darwin Maring Care and Feeding of Molded Fiberglass Trailers 0 09-06-2010 05:04 PM
All new electrical system kyle minor Modifications, Alterations and Updates 4 06-04-2010 11:02 AM
12 Volt Electrical System From Scratch Al POGUE Problem Solving | Owners Helping Owners 2 09-17-2007 08:20 PM
Electrical System Barbara Gardin Electrical | Charging, Systems, Solar and Generators 2 04-18-2006 03:37 PM
