Trailer wiring for accessory outlet - Fiberglass RV
Old 04-11-2015, 07:39 PM   #1
Trailer: Fiber Stream
I'm a newbie to fiberglass trailering - just acquired a 1985 Fiberstream and had everything checked out at RV place. All is fine except Dometic fridge had ammonia leak. I decided to remove it and replace (at least temporarily) with 110V plug-in fridge. While the fridge is out I decided to install some accessory outlets for phone charging etc. using the 12V wiring already there for the Dometic fridge. This leads to my question:
Is it OK to use this wiring - 12AWG wiring on a 15A fused circuit directly from the battery or would I be better off branching off the alternative nonfused (that I can find) interior lights circuit?
Thanks for any help - I have already found answers to many questions on this forum.
Dick from IB is offline   Reply With Quote
Old 04-11-2015, 09:46 PM   #2
tractors1's Avatar
Trailer: Escape 21 - Felicity
12 gauge is fine for accessories, but I'd pull it from your charger instead of direct from the battery unless you don't have an open fuse holder. If you do take it from the battery I would fuse it in the battery compartment if possible.
Charlie Y
Does adding multi-outlet to 12v outlet diminish output? Kudzu Asheville Electrical | Charging, Systems, Solar and Generators 8 05-08-2014 05:05 AM
HONDA TV Accessory Outlet Blows Fuses Bob Miller Problem Solving | Owners Helping Owners 0 09-24-2012 10:13 AM
Awesome Trailer Accessory! Jenny W. General Chat 5 07-30-2010 11:50 AM
Must have accessory Frederick L. Simson General Chat 1 07-07-2007 04:57 PM
Never buy an accessory bigger than the trailer Gina D. Modifications, Alterations and Updates 28 06-29-2006 08:06 PM
