Trillium '75 power cable - Fiberglass RV
Old 10-19-2014, 01:04 PM   #1
Washington, D.C.
The 3 pronged power cable that I plug from my trillium to the wall broke a prong. Is there a whole replacement part, or it it as simple as cutting it open and splicing in any generic replacement? Total newbie at all this.
Thanks in advance. Click image for larger version
Name:	ImageUploadedByFiberglass RV1413745455.356105.jpg
Dietrich is offline   Reply With Quote
Old 10-19-2014, 01:43 PM   #2
Trailer: 13 ft Scamp
Yep, you can buy just the plug and re-wire it to your cable. Just make sure to get the correct amp size.
Darnelle is offline   Reply With Quote
Old 10-23-2014, 11:38 AM   #3
David Tilston's Avatar
Or, you could eliminate the cord and use an extension cord:
Power inlet dimensions needed
My wife liked this, since it is one less place for bugs to get in.
Old 10-28-2014, 08:33 AM   #4
Washington, D.C.
Does anyone know the correct amp size for a 1975 Trillium 1300? Or know how I can find out?
Old 10-28-2014, 08:37 AM   #5
If you have a converter, it is fused at 10A. If not there should be a breaker somewhere. Probably 15A. # 14 Cabtire will be fine.
Or just put a new end on the cable you have.
Old 10-28-2014, 09:04 AM   #6
mszabo's Avatar
Trailer: 1986 Bigfoot FT20
That's a 30 amp plug and 10 ga. Cable you have.
Old 10-28-2014, 09:33 AM   #7
Not to be argumentative, but that is not a 30A cable. That is clearly a 90 15A plug. The protrusion for the ground pin is visible. It could be a 20A, but that is doubtful.
Old 10-28-2014, 10:10 AM   #8
mszabo's Avatar
Is it a 10 ga cable?
Old 10-28-2014, 10:30 AM   #9
Can't tell the gauge of the cable. Cabtire has really thick insulation. But, it would not make sense to use a 10 ga cable on 15A plug. Typically, 14ga for 15A, 12ga for 20A, 10ga for 30A.
A Trillium has no use for 30A. No AC.
Old 10-28-2014, 10:34 AM   #10
mszabo's Avatar
You think someone might of done some southern engineering.
And installed a 15 amp plug on a 30 amp cable?
Saved themselves $5 on a adaptor.
Old 10-28-2014, 11:06 AM   #11
My 1975 Trillium has a 15 Amp fuse for the power cord. It is like a light socket screwed into the bench hatch on the door side. The power cord runs to it then the rest of the trailer.
Don ravinerat is offline   Reply With Quote
trillium
Retractable AC main power cable BrandonC Modifications, Alterations and Updates 2 02-09-2013 06:19 PM
Wanted: Lil Bigfoot power Cable Hatch MsRubyLu-Kathy Parts: Buy | Sell | Trade 15 09-30-2012 07:16 AM
Cable hook up Lenna F Problem Solving | Owners Helping Owners 11 05-26-2008 03:51 PM
television cable Legacy Posts Modifications, Alterations and Updates 6 03-31-2003 01:32 AM
Cable Access Legacy Posts Problem Solving | Owners Helping Owners 4 12-04-2002 04:32 PM
