Trillium Wiring - Page 3 - Fiberglass RV
Old 07-24-2012, 04:54 PM   #29
I would impress upon you and your daughter or anybody else. That when you stop for the night to unplug from the tow vehicle. A blown fuse is easy to fix, but it might be a bit more difficult to start the tow vehicle if you used up both batteries.
Old 07-24-2012, 05:36 PM   #30
Thomas G.'s Avatar
Trailer: For Sale Or Rent
Rooms to Let 50 Cents
Originally Posted by Alex C View Post
I have found a questionable wire route that troubles me so I changed some of the wiring. Let me know if you agree or disagree. I have removed one of the fuses and holder and run the tow vehicle power wire to the supply of the distribution center.
I still think that you need a relay to isolate the two batteries when the engine is not running.
Old 07-24-2012, 06:05 PM   #31
One of my vehicles has a relay, I had it fail. It failed to close so ended up with a dead house battery that I expected the tow to recharge. That was before I had the solar panel.
There almost always a way. I connected my little inverter to tow battery and plugged in a battery charger. Of course I had to burn a bit gasoline to get the house battery charged. But, saved the trip.
Seems like there's no fool proof answer and sometimes the low tech simple works best.
Old 07-24-2012, 06:29 PM   #32
Joe MacDonald's Avatar
You could consider putting a relay in the trailer, hooked up to the shore power (110 volt) for the coil, and run the positive lead going to the tow vehicle through a normally closed contact on the relay. That way when plugged into shore power, the relay energizes, and disconnects the tow vehicle circuit
Old 07-25-2012, 06:52 AM   #33
Alex C's Avatar
That's more typical. You might want to consider changing the 30amp fuse to 20 amp. If you're concerned about that measure the current with the stuff you would normally have on, on.
I originally had a 20amp fuse and found the it keeps cycling when the battery is low and needs recharging from the converter. It put in a 30amp fuse and now it has stopped recycling.
Alex C is offline   Reply With Quote
Old 07-25-2012, 06:55 AM   #34
Alex C's Avatar
Thanks Joe, I found a relay in my electrical parts box and plan to install it just like you have said. Hopefully it still works. Thanks everyone for all your help.
Old 07-25-2012, 07:37 AM   #35
Alex C's Avatar
Originally Posted by AKSCAMP View Post
Thanks for the wiring diagram there. I have to completely rewire my Scamp and I'm having to learn the why and where of isolaters, converters, inverters, etc. Hopefully it helps me once I'm under way.
Here is the wiring diagram with the Relay installed. I installed it next to the distribution center and made up a plug to insert it into a receptacle that was used for the microwave oven. It provided me with the 110v used to power the relay when plugged into Shore Power. I hope it helps.
Old 07-25-2012, 09:02 AM   #36
The size of the fuse has nothing to do with that.
Old 07-25-2012, 09:35 AM   #37
David Tilston's Avatar
Unless it is a solid state, self resetting fuse.
Old 07-25-2012, 01:18 PM   #38
Alex C's Avatar
The Fuse is a can style resetting fuse that has two lugs with nuts attached. I have installed it in the positive line at the battery. When I had the trailer in my driveway I forgot use the battery disconnect switch and wore the battery down. When I plugged it in to Shore Power that 20 amp resetting fuse kept blowing and resetting so, I put in a 30amp fuse and that problem went away.
Old 07-25-2012, 02:04 PM   #39
Thomas G.'s Avatar
I think we are talking about a circuit breaker.
Old 07-26-2012, 10:46 AM   #40
Alex C's Avatar
Circuit Breaker
That picture of the Circuit Breaker is nicer looking than the one I installed. Thanks Thomas for the proper name of that Fuse.
Old 07-29-2012, 09:08 AM   #41
Alex C's Avatar
I redrew the diagram after installing a 20amp circuit breaker to replace the 10amp fuse I had. The relay now prevents me from blowing fuses when I forget to unplug the tow vehicle before plugging in the shore power.
Old 07-29-2012, 11:02 AM   #42
Roy in TO's Avatar
Now all you need is something to cut the power from your tow vehicle when you forget to unplug it and you are not plugged into shore power.
trillium
HELP- - Re-wiring a 74 Trillium 13' Barry Konkin Electrical | Charging, Systems, Solar and Generators 20 10-05-2015 08:35 AM
wiring trillium lights burns Electrical | Charging, Systems, Solar and Generators 11 07-25-2012 06:26 PM
1977 Trillium - Wiring to a 4 Plug gblacketor Problem Solving | Owners Helping Owners 13 04-09-2012 04:48 PM
Vehicle wiring to tow Trillium 13 francene Towing, Hitching, Axles and Running Gear 9 03-19-2009 09:14 PM
Wanted:Trillium wiring diagram Mikey Problem Solving | Owners Helping Owners 1 09-01-2007 05:07 PM
