Originally Posted by Alex C
Here is the wiring diagram with the Relay installed. I installed it next to the distribution center and made up a plug to insert it into a receptacle that was used for the microwave oven. It provided me with the 110v used to power the relay when plugged into Shore Power. I hope it helps.
I redrew the diagram after installing a 20amp circuit breaker to replace the 10amp fuse I had. The relay now prevents me from blowing fuses when I forget to unplug the tow vehicle before plugging in the shore power.
