Truckfridge won't run off converter, why? - Page 2 - Fiberglass RV
Old 08-01-2015, 05:54 PM   #15
Trailer: Casita 17 ft DLX SD
Your converter may not be able to maintain the proper output voltage when subject to the compressor's starting current . If the load on a DC power supply is greater than its rating the power supply will regulate
the voltage to get the current down to a safe level .The battery has no such regulation. As Mr. Miller suggested I would check the voltage at the refrigerator when the compressor is trying to start. "No load voltage is meaningless in this situation" I would speculate that the voltage at the refrigerator is enough to make the compressor hum but not enough to develop sufficient torque to get the compressor to turn/run.
Old 08-01-2015, 08:52 PM   #16
David B.'s Avatar
Name: Dave & Paula Brown
Trailer: Lil Snoozy
Tim, I have the same refrigerator, and when I had our NOVAKOOL 12 volt danfoss style compressor refrigerator, the factory guy told me to hook it up directly to the battery (via a fuse).....I did and never had any problems. I didn't hook up our Truckfridge, as the Lil Snoozy factory installed it for me, but since the Lil Snoozy only comes with a battery charger, it must be hooked up directly to the battery. Hope this helps.
Dave & Paula
Old 08-02-2015, 12:31 AM   #17
truckfridge 130
Specs say 60 watts input should be around 5 amps.
Frank F
frankcfx is offline   Reply With Quote
Old 08-03-2015, 09:17 AM   #18
Here is a troubleshooting page:
https://www.isotherm-parts.com/PDF/s...leshooting.pdf
If when starting the voltage drops below the 10.4 volt level for even an instant then the compressor will lock out. Voltage has to be over 11.7 to reset.
Here is another troubleshooting guide:
http://www.dometic.com/QBankFiles3/E...uide_29020.pdf
This is one reason I got a (very) old swing compressor refrigerator- no starting surge. (noisy however!) The Engle uses swing compressors as well.
fridge
Run off battery? Susanm34 Electrical | Charging, Systems, Solar and Generators 4 06-21-2012 12:24 PM
Electric hitch lift run off the light plug to the truck? Cyndivg11 Problem Solving | Owners Helping Owners 4 04-21-2011 11:16 AM
Tell me why this won't work, and how to make it better JenPB Problem Solving | Owners Helping Owners 23 04-22-2009 07:54 AM
My team won! My team won! Gina D. General Chat 7 02-02-2009 06:41 AM
WE WON!!! WE WON!!! Summer&Brad B. General Chat 19 12-12-2005 07:35 AM
