Uhaul exterior wiring question - Page 2 - Fiberglass RV
Old 06-04-2013, 12:05 PM   #15
mmeyer's Avatar
Trailer: U-Haul VT
Indiana
If you still want to do a 7 pin , I have included pictures from the splitter box that Uhaul used on the VT which came with a 7 pin connector. You should have the same color wires for Stop,tail marker, Turn,etc.just in a smaller package. I probably have a crude wiring diagram somewhere based on my rewire of the beast to my liking. Never could figure out the Master cut off switch, When I rewired it to the way I thought it should be I blew fuses so reverted to their funky method, even today I have to shut it off when on shore power or I don't charge the batteries from the converter.On Solar it works just fine. If you need more info just PM me.The terminals are numbered 1-8 with the following coming in white 8,Blue 7,Yellow6,Brown 5,REd 4,Green3,White 2 Jumpered,Black 1. The outputs can be seen on the cover picture
mmeyer is offline   Reply With Quote
Old 06-04-2013, 12:20 PM   #16
Chris; thanks for the clarification on the wiring and light sockets. Since I replaced all my wiring I couldn't remember what each was in the original harness.
Old 06-04-2013, 11:28 PM   #17
Brian B-P's Avatar
Originally Posted by mmeyer View Post
If you still want to do a 7 pin , I have included pictures from the splitter box that Uhaul used on the VT which came with a 7 pin connector...
If a termination box like this is missing, one is readily available (usually in black, with seven stud terminals in it) for a few dollars from anyone selling supplies for commercial trailers. They are suitable for outside mounting, and I use one on the tongue of my Boler to tie the cable from the tug to the trailer wiring. This is much more accessible than the rat's nest of wires under the dinette seat that Boler created.
Exterior cleaning question Scamp suffocate Care and Feeding of Molded Fiberglass Trailers 5 02-16-2013 07:34 PM
UHaul Tailight Wiring - How is it supposed to be? Thomas G. Electrical | Charging, Systems, Solar and Generators 15 01-21-2013 12:10 PM
UHaul CT 13 TV Wiring Thomas G. Modifications, Alterations and Updates 5 12-04-2011 05:54 PM
CT13 - Exterior Lighting Wiring Wolfyjedi Electrical | Charging, Systems, Solar and Generators 4 09-13-2011 05:39 PM
question re: exterior decoration for our casita joy mccalla Care and Feeding of Molded Fiberglass Trailers 29 11-21-2010 11:28 PM
