UHaul Tailight Wiring - How is it supposed to be? - Page 2 - Fiberglass RV
Old 01-21-2013, 11:37 AM   #15
knighth001's Avatar
Trailer: 1984 Uhaul CT 13
Originally Posted by Thomas G. View Post
It worked out great. I combined the two hot wires on the amber socket so my turn signals are extra bright. (It energizes both the low and high filaments).
You could use the 5th connector to charge your battery when you drive. If you do it, use 10 gauge wire as a minimum.
Nice! I'll look into getting one of those. I was thinking of maybe going to a 7-pin at some point. Even thought I don't have brakes, I was thinking the aux power for charging and eventually a backup light behind the trailer would be nice additions.
I do have one question since I have only done wiring on boat/utility trailers before. Did you put a fuse on the aux power line on the TV side? If so what size fuse?
--Sean
1984 Uhaul CT 13
TV: 2011 Kia Sorento V6, 2001 Mazda Tribute V6
My U-haul Camper Blog
knighth001 is offline   Reply With Quote
Old 01-21-2013, 12:10 PM   #16
Thomas G.'s Avatar
Trailer: For Sale Or Rent
Rooms to Let 50 Cents
Originally Posted by knighth001 View Post
...... Did you put a fuse on the aux power line on the TV side? If so what size fuse?
When I wired up my TV to charge the trailer I used a small 30 amp relay and a 30 amp circuit breaker in series. That way it disconnects automatically when the TV is not running and if it should get shorted out, it will pop the breaker before it over heats the wire.
uhaul
UHaul CT 13 TV Wiring Thomas G. Modifications, Alterations and Updates 5 12-04-2011 05:54 PM
How is a vent supposed to be attached to a roof? Paul McEwan Problem Solving | Owners Helping Owners 41 05-29-2011 10:51 AM
Boler - what's this Plaque supposed to say? Peter_Crowl Care and Feeding of Molded Fiberglass Trailers 15 03-31-2011 05:33 AM
LED tailight mod..... kentj Modifications, Alterations and Updates 6 06-18-2008 09:48 AM
Tailight Question Ken Ford Problem Solving | Owners Helping Owners 5 05-14-2006 03:28 PM
