UHaul Tailight Wiring - How is it supposed to be? - Fiberglass RV
Old 12-07-2011, 03:16 PM   #1
Thomas G.'s Avatar
OK, I've searched and not answered my question, so here goes.
On the CT13, are the rear amber lights for the turn signals and the red lights for brake and running lights? If so, how do they accomplish that with a 4 way connector?
I'm adding an additional wire for charging so I need to understand how many wires in total I will need to make it work correctly.
Thanks.
Old 12-07-2011, 03:25 PM   #2
Bruce Thomas's Avatar
Trailer: U-Haul CT13
Thanks.
you cant...the uhauls were made when alot of cars had amber turn signals in the rear and would require at least a 6way to pull that off and thats what they came with. you can do it with the modern 7way and napa makes an adapter to convert to the 6 on the trailer..i towed my home with one a few years ago. Currently we use just the reds and have not wired in the ambers up at the hitch......so just a 4way........Bruce
Bruce Thomas is offline   Reply With Quote
Old 12-07-2011, 04:01 PM   #3
Thomas G.'s Avatar
Thanks. It looks like I can solve this problem for $20 with this adapter that adapts a 2 wire input into a 3 wire output, giving back the amber turn signals, which is my preference.
http://www.amazon.com/Curt-56196-Man...3306011&sr=8-1
I recall now that 25 years ago when I rented this trailer they installed bulbs in the TV with two wire lead wires and the trailer had bullet connectors that were plugged into the bulb lead wires.
Old 12-07-2011, 09:04 PM   #4
djtriceflt's Avatar
Trailer: 1985 U-Haul CT-13
Thumbs up Converter
Tom, You are correct about having to install a converter to get back to the 3 way. I also installed a junction box underneath the propane tank up front and put the converter (two way to 3 way) inside the housing that holds the propane tank to keep it out of the weather. I use the round 7 spade connector plug as I wanted the battery to have charging from the tow vehicle and there is an extra two circuits for electric brakes and backup lights if you should desire. The converter was easy to install and has worked faultlessly so far! Happy Trails,
don '85 Ct-13
djtriceflt is offline   Reply With Quote
Old 12-08-2011, 06:09 AM   #5
Thomas G.'s Avatar
Originally Posted by djtriceflt View Post
......... I also installed a junction box underneath the propane tank up front and put the converter (two way to 3 way) inside the housing that holds the propane tank to keep it out of the weather ............
I like this plan. Any tips on which junction box to purchase, i.e. did you use a 110v exterior grade box or something smaller?
Old 12-08-2011, 09:41 PM   #6
djtriceflt's Avatar
Thumbs up Junction box
Tom,
The junction box I used is a common RV box that has a number of openings with rubber grommets to allow various configurations. I like it because it really is a clean installation and weatherproof. I mounted it on the left side of the propane pedestal with the converter box mounted inside the pedestal underneath the propane tank. I drilled a hole in the pedestal just above the junction box to allow the converter and ground wires to pass through. I will try to take a pic and send it to you as soon as I get a chance but been really busy lately. I also need to get some other pics soon as CindlyL has reminded me!
Happy Trails,
don '85 CT-13
"Sometimes the hunt is better than the catch"
Old 03-20-2012, 06:36 PM   #7
Thomas G.'s Avatar
Follow Up:
It was a beautiful day in SE Michigan so I tackled my tail lights.
I replaced all clinched connectors with soldered connections covered by shrink tubing. I even soldered my grounds to the trailer frame. Not too hard with a propane torch and low temperature solder.
Oddly, the UHaul has twin filiament bulbs in both the upper amber (turn) and lower red (tail / brake) light positions. The PO was evidently confused having 5 wires on the light and 4 connectors from the trailer, so he decided the ground was not needed. I connected the two upper filaments together to give me slightly brighter turn signals and ran a new, secondary ground to improve reliability.
Also of interest was a dead short in my brake light circuit. I tracked it down to the bulb socket. There are two little 1/2 round balls in the bottom of the socket which connect to the two 1/2 round nubs in the bulb base. On the back of the 1/2 round balls in the socket are the wires which power the socket. I found those wires had a few loose strands that were able to touch the side and ground themselves out. I slid shrink tubing down tightly on them.
I still need to attack the license plate light, the clearance lights and add an electronic adapter to allow for the amber turn signals.
Old 03-20-2012, 09:23 PM   #8
So what is the purpose of a double filament bulb in the amber section. I did have mine wired so that both amber and red were stop / turn lights, but another member here pointed out that setup may be confusing to other drivers, so now the amber is disconnected. I have a bike rack on the rear that has red tail / turn lights on it so that should provide enough lights. I also put some conspicuity tape on the bumper and the bike rack so there's no excuse for anyone to rear-end me. I had thought of covering the amber part of the lens with that red lens repair tape, but it looks cheesy. I have a set of the adapters to convert to a round tail light but don't like the looks of them. Wonder what ever happened to the guy who was trying to make new lenses?
Old 03-21-2012, 05:06 AM   #9
Thomas G.'s Avatar
Originally Posted by mary and bob View Post
So what is the purpose of a double filament bulb in the amber section...........
My guess was to make all bulbs the same to minimize error by UHaul personnel.
That said, leaving an extra unplugged terminal causes an opportunity for a mess up, as I witnessed.
Old 03-21-2012, 05:56 AM   #10
What kind of mess up have you seen????
Old 03-21-2012, 06:27 AM   #11
Thomas G.'s Avatar
My tail light assemblies were ungrounded except the grounding wire was hooked to one filament of the bottom bulb.
Old 01-15-2013, 10:05 PM   #12
Chris Jones's Avatar
Trailer: U-Haul
Georgia
Curt Manufacturing 56196 Converter : Amazon.com : Automotive
Up till about 2005 we used the Tap A Lights you are talking about and still used the bullet connectors until then as well. That's when the massive change over to the 4 Flat we all use now.
Chris Jones is offline   Reply With Quote
Old 01-21-2013, 12:02 PM   #13
knighth001's Avatar
Trailer: 1984 Uhaul CT 13
Georgia
Tom, how did this work out for you? were you able to wire the amber lights to work? PO put a 5-wire plug on mine. I'm still not sure what the 5th wire does yet. The amber turn signals on my trailer appear to not be connected (or maybe they're the fifth wire). All the other lights work and my red tail/brake lights work as turn signals right now too. I'd like swap back to using the amber signals if possible.
--Sean
1984 Uhaul CT 13
TV: 2015 GMC Acadia V6, 2008 Jeep Wrangler Rubicon, 2001 Mazda Tribute V6
My U-haul Camper Blog
knighth001 is offline   Reply With Quote
Old 01-21-2013, 12:17 PM   #14
Thomas G.'s Avatar
It worked out great. I combined the two hot wires on the amber socket so my turn signals are extra bright. (It energizes both the low and high filaments).
You could use the 5th connector to charge your battery when you drive. If you do it, use 10 gauge wire as a minimum.
Old 01-21-2013, 12:37 PM   #15
knighth001's Avatar
Georgia
Nice! I'll look into getting one of those. I was thinking of maybe going to a 7-pin at some point. Even thought I don't have brakes, I was thinking the aux power for charging and eventually a backup light behind the trailer would be nice additions.
I do have one question since I have only done wiring on boat/utility trailers before. Did you put a fuse on the aux power line on the TV side? If so what size fuse?
--Sean
1984 Uhaul CT 13
Old 01-21-2013, 01:10 PM   #16
Thomas G.'s Avatar
...... Did you put a fuse on the aux power line on the TV side? If so what size fuse?
When I wired up my TV to charge the trailer I used a small 30 amp relay and a 30 amp circuit breaker in series. That way it disconnects automatically when the TV is not running and if it should get shorted out, it will pop the breaker before it over heats the wire.
uhaul
UHaul CT 13 TV Wiring Thomas G. Modifications, Alterations and Updates 5 12-04-2011 06:54 PM
How is a vent supposed to be attached to a roof? Paul McEwan Problem Solving | Owners Helping Owners 41 05-29-2011 10:51 AM
Boler - what's this Plaque supposed to say? Peter_Crowl Care and Feeding of Molded Fiberglass Trailers 15 03-31-2011 05:33 AM
LED tailight mod..... kentj Modifications, Alterations and Updates 6 06-18-2008 09:48 AM
Tailight Question Ken Ford Problem Solving | Owners Helping Owners 5 05-14-2006 03:28 PM
