Uses for Exterior Outlet - Fiberglass RV
Old 07-03-2013, 08:25 PM   #1
Gilda's Avatar
Trailer: 2011 Scamp 13'
I don't remember ordering this option, but there it is, an exterior ground fault outlet on the door side of my 13' Scamp. In your experience what do you use it for? I suppose it's helpful if you want to plug in your outdoor string lights. What else is it used for?
The Gleeful Glamper
Gilda (Jill-da)
Old 07-03-2013, 08:38 PM   #2
Joy A's Avatar
Lets see, hum!!!
1. Coffee pot
2. Fan
3. Toaster oven
4. Crock pot
5. Electric drill
6. Small router
7. Hair dryer while drying the dog
8. Lap top
That's all I can recall at the moment.
Joy A. & Lily
and "Puff", too
No. Ca. Sierra Foothills
Old 07-03-2013, 08:44 PM   #3
Jim Bennett's Avatar
Trailer: 2017 Escape 5.0 TA
Well, we don't bring along any of the same things Joy does. I like to keep the weight down, and also don't want to be reliant on 120V for anything. Pretty much all I have ever used ours for, is a small electric kettle we bring along for the rare occasion we are hooked to the grid so I can heat water for coffee. Other than the odd charger, a small electric heater for inside is the only 120V stuff we carry at all.
For those of us who mostly boondock, an exterior plug does not get much use at all.
2017 Escape 5.0 TA
2009 Escape 19 (previous)
Old 07-03-2013, 08:44 PM   #4
Trailer: Casita 17 ft DLX SD
We cook breakfast outdoor on an electric griddle . We plug an extension cord into the outside outlet and set the griddle up on the picnic table . Keeps the trailer cool and clean . Great for cooking pancakes , french toast or anything that splatters grease such as bacon . The only problem we had was that Scamp puts the kitchen outlet on the same circuit as the outside outlet so we tripped the circuit breaker on occasion
steve dunham is online now   Reply With Quote
Old 07-03-2013, 08:58 PM   #5
Joy A's Avatar
Well I too boondock and have used the outside outlets on occasions. I simply start up the generator.
I get antsy when I have a project to do. A number of years ago I had purchased a locking electrical compartment door so while boondocking I installed it using the generator and router to cut the hole. That mod ended up being the latest mod to show off at the Oregon gathering.
I like the idea of an electric griddle. It's been in the 100's here in CA so if I were camping I'd not want to cook inside. However if there were bugs around I'd just start up the A/C and cook inside.
Joy A. & Lily
and "Puff", too
Old 07-03-2013, 09:04 PM   #6
Trailer: 2014 Escape 21
Virginia
We use it for outside cooking like others. I also plug in a small bathroom led night light. It lights up the door step and ground just in front of the door. Good when you come into the campsite after dark or returning from bathroom late at night. Does not disturb the neighbors like the upper door light. I just leave it plugged in, it turns on at dusk and off at dawn.
Eddie
Old 07-03-2013, 09:09 PM   #7
Having never used a genset with my trailer, I never thought about the uses it would afford.
2017 Escape 5.0 TA
Old 07-03-2013, 09:59 PM   #8
Brian Van Snell's Avatar
Trailer: Escape 13 ft 2010 ('Ladybug') / 2003 Subaru Forester/ 2012 Toyota Highlander
Steve:
We had a similar problem until I noticed that the current bush at many campsites has a 15 amp standard outlet as well as the usual 30 amp RV outlet. We have a small table outside our trailer where out toaster, electric kettle and electric frying pan live and they are connected via an extension cord to the 15 amp outlet mentioned above. This way we can use our electric heater inside in the winter and run the electric kettle outside and not trip a breaker. We prefer cooking outside most of the time to avoid steaming up and smelling up the trailer.
When we are boondocking we use a small propane stove outside to do most of the cooking and the propane furnace for heating (if needed).
We have an outside power outlet too but we don't use it much since discovering the "current bush" solution.
Brian
Brian & Maria
2010 Escape 13 "Ladybug"|2003 Subaru Forester|2012 Toyota Highlander
Brian Van Snell is offline   Reply With Quote
Old 07-03-2013, 10:01 PM   #9
Administrator
Mary F's Avatar
THAT's a good idea, Eddie!
We also have a small-ish (4 qt?) "roaster oven" which is somewhat like a crock pot, except it isn't a slow cooker. It's great for cooking beans (or a chicken). I use it outside, plugged into that outlet, in part to keep the heat out of the trailer, but also because there's no counter space for using it inside.
That outdoor plug is kinda like the air conditioner in that we don't use it often, but when we need it, it's a nice thing to have. And yeah, mostly we use it to plug in the party lights.
Mary F Fiberglass Rules!
FGRV Forum Custom Search
Old 07-03-2013, 10:03 PM   #10
IllAnnoy
We use it for awning lights
Old 07-04-2013, 12:11 AM   #11
About the only time my outside outlet is used is when the trailer is in it's nest and needs a good vacuuming out.
Other than nest time there no good current bush around.
Old 07-04-2013, 04:46 AM   #12
frank_a's Avatar
Trailer: 2012 ParkLiner #006
Coffee pot and toaster, about all I want in the a.m. Have a portable gas grill for cooking, as well as one in our old trailer.
While we don't bring it for weekend trips, we have a big Cabela's camp kitchen we bring for extended stays and a screen enclosure for it. This is left over from our tenting days, or should I say decades...
Frank
Old 07-04-2013, 05:00 AM   #13
honda03842's Avatar
Name: Norm and Ginny
Our most common use is when working on the trailer.
Norm and Ginny
2014 Honda Odyssey
1991 Scamp 16
Old 07-04-2013, 06:01 AM   #14
There is that too. It is handy when parked at home doing projects on the trailer.
2017 Escape 5.0 TA
Source for a 110v exterior outlet FlyboyTJ Modifications, Alterations and Updates 49 10-20-2012 06:38 PM
exterior access hatch and exterior shower aimeelightsey General Chat 36 10-06-2012 03:15 PM
Need help with exterior 110 power outlet install Carol H Electrical | Charging, Systems, Solar and Generators 25 08-20-2012 12:33 PM
12 volt outlet RonMayo Modifications, Alterations and Updates 9 08-21-2008 06:45 PM
Adding 12 v outlet Legacy Posts Problem Solving | Owners Helping Owners 3 08-19-2003 08:06 AM
