05-04-2012, 02:29 PM
Trailer: 1978 Trillium 4500
What are your favorite electrical features ...
All,
As part of my redo, I'm building a list of desirable electrical features in an egg.
As an example:
* interior switch for the "patio" light
* Main battery cut off
* 12 volt external outlet
* cabinet light with automatic on/off switch
... and so on
What are your favorite electrical features?
Cheers
--Fred and Natalie
1978 Trillium 4500 "Bernerwagon"
05-04-2012, 02:47 PM
Multiple Grounds so I don't have to worry about things not working.
05-04-2012, 02:48 PM
Electric Hot Rod in the water heater so I can get free hotwater at campgrounds instead of using my propane.
05-04-2012, 03:14 PM
USB charging port
05-04-2012, 03:22 PM
Name: Norm and Ginny
We've done a lot of electrical work to our trailer.
Electric rod in water tank so I don't have to hear the water tanks propane burner, saves propane.
Extra AC outlets, we have 8 inside (1 under couch for Converter and Sat receiver) and 1 under sink (for water heater electrical hot rod and air conditioner) and 1 outside on door side plus 1 in fridge bay.
Extra DC outlets 2 inside (useful for small inverters and electronic devices) and one in fridge bay, useful for running compressor.
80 watt roof solar panel.
Wifi hotspot/booster.
1200 watt Inverter.
Cable and Sat dish input jacks.
Expanded breaker box to four 15 amp breakers.
LED bulbs in lights,
Addditional lights, spot over couch and two lights over dinette.
LED Tail lights.
Planned:
Grid AC to Inverter AC switch.
Second Battery.
Improved LED bulbs (an area that seems to get better with time)
Quick conect AC cord to get AC power cord out of the trailer.
Looking for lowest current water pump, ours draws 7 amps.
It's a lot but I'm somewhat of an electrical person. I know the number of AC outlets seems excessive but I notice we use everyone sometime during the day between chargers, computers, toaster and coffee pot. The least used outlet is the outside pair.
The inside DC outlets are used a lot when boondocking. We put a 100 watt cigarette lighter inverter in each one, one near the TV and one near the Sat dish. The outside DC outlet is only used for our small RV compressor when I'm topping off the tires.
We want to get the AC cord out from under the dinette, mostly because we want to install a larger water tank, plus we rarely pull out that cord more than a few feet.
Hope that helps
Norm and Ginny
2014 Honda Odyssey
1991 Scamp 16
05-04-2012, 03:27 PM
Having all but one of my lights LED to keep the power consumption down when not attached to electricity.
Having the controller for my portable solar panel permanently mounted and attached to the battery, so all I have to do is plug in the portable solar panel to it when needed without having to play around with the battery attachments.
A 110 outlet outside and a 110 outlet located lower down towards the floor inside for times when you want to use the electric heater instead of the trailers propane heater.
Having 110 outlets at the ends of the cabinets on the dinning table side is great for using a lap top or charging phones with out having the cords hanging down the kitchen area of the trailer just waiting to be tripped over & also great if you are using a toaster or what ever - you dont have the cord running over the middle top of the counter as you do with outlets located at the front of the counter.
Edit: forgot to add the 12 volt inside outlet for charging things such as phones & cameras when not on the power grid. Have a couple of plug in adapters for them to cover normal plugs as well as usb.
05-04-2012, 03:59 PM
a few (more than you would think you'd need) 12 V outlets, plus a bunch of 110V outlets. A 110 plus a 12V outlet in the bathroom.
Lights inside cabinets and closets
An easy-to use battery disconnect switch
A 110 V outlet on the driver's side of the coach, near the water heater for plugging in the Hotrod
05-04-2012, 04:23 PM
Trailer: 2010 Scamp 16
I remember seeing battery disconnect jacknife switches that attach right at the battery. Goes on terminal and provides connection terminal on other side of switch Complete Battery source was the store. Not sure about cost but less than $30 is what I recall.
05-04-2012, 04:37 PM
WHat's the purpose of a battery disconnect?
Norm and Ginny
2014 Honda Odyssey
1991 Scamp 16
05-04-2012, 05:38 PM
Trailer: Casita patriot deluxe (sold)
Virginia
LED, lamps, Vortex (1) speed Vent fan, Bracket for American flag.Right front corner, 12 volt Cig. receptacle inside.
sparky1 in s.Va.
05-04-2012, 06:11 PM
An electrical feature? Does my Mr. Coffee count? . I'd rather not have lights than do without coffee in the morning.
05-04-2012, 06:13 PM
Trailer: 93 "Lil" Bigfoot 13.5'
Utah
A power line up to the ceiling vent hole,,, for an add on fan.
05-04-2012, 06:28 PM
Refrigerator fan (inside and outside).
05-04-2012, 07:01 PM
Disconnect battery from trailer wiring for working on electrical, possibly during storage to avoid micro draw from things like stero. I used something like this for a two battery system that only used one at a time to power camper.
Kids had habit of leaving stuff on like bathroom light and radio so was set up to draw from one battery only, while other was in reserve. 12v water pump and unexpected dead battery while in boondocks prompted that. I could "switch" each battery on/off line.
Honestly not sure why one would want one typically. Unless they mean quick connect/disconnect plugs of some sort?
05-04-2012, 07:09 PM
Solar charging! Vent fan and LED light bulbs would top my list. Followed by 12v plug for charging. Currently I can charge phone or laptop in car.
05-04-2012, 07:39 PM
So when my trailer sits for a few weeks (months?) at a time the parasitic loads of gas/CO detectors, keeping fridge circuit boards etc "alive; don't run the battery run down and kill it. What I do now is just pull connections off one terminal, but a straightforward disconnect switch is a great plan. And I even have one (from a race car - they are cheap and reliable as the sun, weatherproof and easy to use) but I can never seem to find any "tuits" that are round.
05-04-2012, 08:23 PM
Virginia
Donna.!!!..no use camping if you Don't have coffee,might as well just stay home.
05-04-2012, 08:29 PM
Originally Posted by freddo411
All,
As an example:
... and so on
Large LED warning light for the shower sump (Scamp), 400W tru-sine inverter. extra porch light at the tongue and at the port side for hook-ups. Several 12V outlets, including one inside the door but outside the screen. LED tail lights up high for obvious reasons.
05-04-2012, 08:39 PM
Virginia
actually I HATE the door light ---turn it on---it blinds you---I want something Nice---add a orange light (running) near (under the door) light the ground--or if you have a step-light it-.bugs are NOT attracted to a orange light.surely you can find the door lock.I'm thinking about a Single LED near the door handle.some older Chrysler products had them on front fenders (turn signal).
sparky1.
05-04-2012, 08:56 PM
Forgot to say
A light to announce that the water pump is turned on. Maybe with one of those I can stop forgetting to turn it off when towing.
(yes, it's on my checklist, but sans light....)
AND another light to say that the water HEATER is on as well
