What can I run and not run on my home electricity? - Page 2 - Fiberglass RV
Old 06-18-2016, 05:53 AM   #21
Originally Posted by GregandTeresa View Post
OK, my outlet is the 15 amp, so I would need to change that out?
Unfortunately it is not quite that simple. Typically the wire used would be 12 gauge for 20 amps and 14 for 15 amps but even if you verified that 12 gauge was used there is more to consider. Generally, I was talking about a dedicated 20 amp outlet (such as the one for my central vac). Of course if there is something else on the same circuit and you are drawing 20 amps for your camper, then you should expect that to overload the circuit. There are a few other issues to consider also but the bottom line is, I would stick with the 15 amp plan. If you do want to get a 20 amp outlet, get a licensed electrician to at least look at it. Improperly wiring your house can lead to a fire.
Old 06-18-2016, 06:16 AM   #22
Raz
Raz's Avatar
Vermont
Good advice.
Can I run fridge on AC mode with full cover on Casita? Joe & Cherie General Chat 15 04-06-2016 11:56 AM
Can I run my Hot Water Heater Karalyn Plumbing | Systems and Fixtures 8 06-22-2009 10:53 AM
Upgrading our water heater to work on gas and electricity peterh Modifications, Alterations and Updates 5 05-02-2009 11:36 PM
No electricity in your home, no problem! Donna D. General Chat 11 01-19-2009 12:22 AM
Plumbing and Electricity Diagram BobA Electrical | Charging, Systems, Solar and Generators 5 06-28-2007 07:33 PM
