what happened? Lights now dull. - Fiberglass RV
Old 12-25-2015, 03:27 PM   #1
Trailer: 2001 Scamp 16 layout 3
Unhappy what happened? Lights now dull.
Replaced 2002 Scamp bulbs with LEDs. Worked great. Decided to add another light by doorway. Added third black wire to where 2 black wires connected (since splits to run 2 lights). Did same with white wires. After wiring it wouldn't light. Disconnected and hooked it back up the way it was. Now lights on one side of trailer light but are dull. When I turn them all on one doesn't even light. I am plugged in to house so nothing to do with battery. What happened?????
denny w is offline   Reply With Quote
Old 12-25-2015, 04:12 PM   #2
Timber Wolf's Avatar
North Florida
These things can be very frustrating. Check the simplest things first. Usually something you did, recheck all messed with connections. Maybe you tugged on a wire and it came loose somewhere else?
Old 12-25-2015, 04:30 PM   #3
But why dull? Shouldn't they either light or not?
Old 12-25-2015, 04:55 PM   #4
North Florida
I don't know but if the LEDs might act "funny". Before I changed out the old converter for a new PD one my new LED lights would flash with one fan running, but not with two or no fans running.
My first, uneducated guess when I hear dull lights is "bad ground" but as the LEDs don't pull much juice I don't know.
Again, check the simplest stuff first, you did something.
Old 12-25-2015, 05:10 PM   #5
Cathi's Avatar
POBox 1267, Denison, Texas
I understand that you can trip something but still see a dull light.
Old 12-25-2015, 06:13 PM   #6
If U bought the really cheep LEDs then connected them up backwards, you may have burned out some of the diodes. The more expensive LEDs can B connected either way because they contain circuitry to do that.
If you have a faulty ground they may not light up fully.
Just recheck all your wiring. On the DC side of wiring I like to use RED for + and BLACK for - . A C wiring, Black for hot and white for return and green for ground.
Old 12-26-2015, 06:03 AM   #7
Question Now really confused due to hooking up wires
3 times while working on them they came up very dull and if I turn a lot of them on some don't light up at all. 3 times I give up and turn them off and come back later they all light up bright. They are working now brightly. Can power be reduced temporarily and then reset to full power due to the hooking up of wires "sparking" or something?
Old 12-26-2015, 08:46 AM   #8
Poor Ground is the most common problem in wiring .most trailers white is power as for the leds not lighting swap the wires around . had the same problem on mine .also in mine black had power .use a multi meter to confirm.
MAP 56 is offline   Reply With Quote
Old 12-26-2015, 09:55 AM   #9
Jon Vermilye's Avatar
Trailer: 2017 Escape 21
Oswego, NY
I'm glad they are now working OK. One other thing to look for other than a bad ground -
If you are powering the LEDs from a converter that has a blown fuse indicator LED on the panel, you may have blown a fuse. The LED lighting fixtures draw so little current that they will glow dimly if they are the only thing on the circuit even with a blown fuse because the indicator LED on the converter passes enough current to make them glow.
Old 12-26-2015, 11:13 AM   #10
Bob in Mb's Avatar
Trailer: Surf-Side
Manitoba
Just wondering if cold temperature may affect some LED lights - just a thought .
Bob in Mb is offline   Reply With Quote
Old 12-26-2015, 12:11 PM   #11
Trailer: G30 Elite Class C
did u install a ground, poor ground could cause the problem
: most times when the lights are dull or weak means loose ground wire or not connected at all.
Stude
stude is offline   Reply With Quote
Old 12-28-2015, 07:16 PM   #12
Wink best answer
Thanks for all the help!!!!!! Best answer to my ex-problem with very dull LEDs seems to be that the converter cut the power while I was working on them every time and they just glowed. After it reset they stopped glowing and have lighted brightly ever since. Several times after I worked on them it seemed to reset on its own after a period of time left alone. Does this make sense since I didn't do anything to the box any of the 3 times?
light, lights
Brake Lights, Turn signal lights, marker lights, oh my! glamourpets Problem Solving | Owners Helping Owners 19 01-03-2013 09:10 AM
dull spot on the roof.... PatJul Problem Solving | Owners Helping Owners 6 06-30-2008 03:10 PM
Well, it's finally happened... Nancy in Oregon Rallies, Get-togethers, Molded Meets (Archive) 2 04-10-2006 10:52 AM
What happened(In the dark here) Kev&Melis B. General Chat 3 11-13-2005 09:09 AM
