Anyone thinking of buying an Optima Blue top battery should note that there are 2 different blue tops, so make sure you get the right one! This is from
Optima's website;
"BlueTop: The BlueTop starting battery (dark gray case) is to be used when a dedicated starting battery is required and it should never be used for cycling duty. The dual purpose BlueTop (light gray case) can be used for both starting and deep cycling; it is a true deep cycle battery with extremely high cranking power.
Trolling motors, marine applications with heavy
electrical accessories and RVs should use a dual purpose BlueTop (which is both a starting and deep cycle battery)
Use a BlueTop starting battery for marine applications and RVs when the battery’s only function is engine starting
Note: The difference between BlueTop and YellowTop deep cycle batteries is that BlueTop batteries have both automotive (SAE) posts and threaded posts, while YellowTops (other than D31T) only have SAE posts.
If you ever get confused on the color tops just remember: if it has a dark gray case then it is a starting battery; if it has a
light gray case then it is a deep cycle (dual purpose) battery."
They also confirm the battery needs to be vented if placed inside a passenger compartment, and that their batteries have ports for connecting a vent hose.
John
