What size replacement converter? - Fiberglass RV
Old 08-06-2015, 01:59 PM   #1
Timber Wolf's Avatar
North Florida
It looks like next month's Scamp project is a new converter. I had decided on a PD9245 as I have previously reworked the AC side of things and just want a new converter and “smart” charger. But after reading a few posts on other RV sites this week I come to understand a rule of thumb is to choose a converter with approximately 25-30% of the amperage capacity of your batteries.
I now have two 6V GC2 batteries on the tongue so 225X.25 or 30 is 56 to 68 amps. Or a PD9260 or PD 9270, the 70 is actually a little cheaper on Amazon. The only downside (besides an upfront increased cost of $50) I see to the larger converter is having to upgrade my battery wire from 10 gauge to at least 8, something that I am not opposed to and was thinking of doing anyway (except I already have #10 on hand).
The only real upside I see to the larger converter is possibly faster charging. Which will only really matter in the unlikely event I have to recharge off a generator (yes, I wrote the “g” word). I will be going solar soon, and hope that I will never need a generator but never say never, and I do have one anyway.
So, what say ye?
Old 08-06-2015, 02:09 PM   #2
Thats' a rather strange formula. I have never seen a charge rate much higher than about the 12 amps run by my PD-4045 with a battery that was drawn to just below 12 volts. These are "Smart Chargers", and, apparently, are smart enough to know that high charging rates are unkind to battery's and other living things.
The 45 amps mean to ME, that I have more than enough capacity to charge two batteries and run the 12VDC accessories at the some time.
Old 08-06-2015, 02:29 PM   #3
EllPea in CA's Avatar
CA
Bob, do we need a converter to charge the battery with shore power? Is it needed to charge battery from vehicle?
Best,
EllPea in CA
EllPea in CA is offline   Reply With Quote
Old 08-06-2015, 03:11 PM   #4
As I mentioned earlier, our Lil BigFoot came with a separate converter and battery charger, but I came to the conclusion that the battery charger part of the converter had stopped working and eventually just replaced the whole mess with a Progressive Dynamics PD-4045 power center.
Can you tell us what converter/power supply is currently installed?
If you have a 7 pin plug from your TV to the trailer, that usually indicates that there is a charging line and the battery will charge when you are driving. If not, it usually can't.
When you are plugged in to shore power the converter "Usually" also charges the battery. Look under the left bed dinette seat and tell us what you find. A picture would also help.
Last question: Do you have a small multi-meter and know how to use it? That opens a whole door to answer the questions you are asking. Makes it easy-peasy.
If you don't have a multi-meter you really should have one, they are inexpensive and very useful when problems with a new-to-you FGRV arise.
Old 08-06-2015, 04:06 PM   #5
Cross referencing to this thread.
Old 08-06-2015, 04:10 PM   #6
CA
I do have a 7-pin plug, but don't see a converter under the bunk. I only find a two-circuit breaker box under the sink.
Battery is not currently charging under shore power, but the inside power outlets do work...
Not sure about multi-meter. Ron has the volt-tester, this is probably different?
LP
Best,
EllPea in CA
Old 08-06-2015, 04:26 PM   #7
A volt tester will work fine as long as it is digital and can read to two decimal places.
It sounds like yours was built without a converter and depends on the battery alone for 12VDC. In that case, an inexpensive (10+ amp) Battery charger can be used to keep the battery up when on shore power. Right now read the exact voltage on the battery, then plug it intro the TV, start the engine and read it again. It should jump up to about 13.5+ volts when the engine is running, indicating that it is being charged.
Old 08-06-2015, 04:46 PM   #8
CA
I can't plug into the TV right now, still waiting for hitch installation. And the Aerostar only has a 4-pin plug. We've read the voltage on the battery, and then plugged in shore power, and there's no change. Does that mean anything?
We have a trickle-charger. I think we have plugged that in overnight with no difference. The voltage reads 12-something, no change after plugging.
It was *supposed* to be a new battery that had run down due to sitting in storage. Would taking it for a deep charge make a difference?
Best,
EllPea in CA
Old 08-06-2015, 06:15 PM   #9
The entire world of battery voltages lies between about 12.0 and 12.8 volts. "12 something" doesn't tell us much. If the battery sat for several years without being used or recharged it will have sulfated and it's bye-bye battery.
Now, if that 12 something is 12.8, the battery is fully charged. if it's 12.2, the battery is below 1/2 charge and should not be used. But it may be to late and it's time for a trip to Wal-Mart.
"Trickle" chargers are designed to maintain charged batteries, not to charge a dead battery.
If you take it to a Auto-Zone store they will charge it for free and do a load test.
Old 08-06-2015, 06:19 PM   #10
So, you take your battery to Auto-Zone for a free charge and load test, and then go to Walmart to buy a battery? Is that the plan?
Old 08-06-2015, 06:29 PM   #11
CA
argh. Well, I can't remember the 12.what, but it was low. 12.2 does sound right. We'll take it in and see.
So am I correct in understanding that if we don't have a converter, the battery will not charge off of shore power? Sorry for really noobee questions, but the power bit of this will take me a while to get a handle on.
Best,
EllPea in CA
Old 08-06-2015, 06:31 PM   #12
They also load tools, even if you don't buy the parts you are installing from them. I think that they call it "Customer Service". I call it Karma
Old 08-06-2015, 06:36 PM   #13
CA
Mighty mini
Is this the one?
http://www.amazon.com/Progressive-Dy...5+power+center.
Best,
EllPea in CA
Old 08-06-2015, 06:38 PM   #14
Yep, you have to have a converter or a separate battery charger. Either one can do the trick, but a Converter with a built in smart charger is the cats meow. This is the one I always recommend. I have installed about 7 PD-4045's at last count:
Mighty Mini All-In-One System AC/DC Power Distribution Panel and Inteli-Power Converter
Scamp Full Size Bed = Smaller Table Size TomK General Chat 49 10-03-2015 01:17 PM
Trillium 4500 replacement converter? spotcatbug Modifications, Alterations and Updates 68 07-23-2013 10:58 AM
Battery replacement= Converter clicking on/off iplumb Electrical | Charging, Systems, Solar and Generators 11 03-31-2013 03:52 PM
Replacement converter/charger Davie B Modifications, Alterations and Updates 13 06-30-2011 05:25 PM
What size converter? Whaler Problem Solving | Owners Helping Owners 10 04-07-2011 04:05 PM
