What to do with extra tail light wire? - Fiberglass RV
Old 04-28-2017, 03:14 PM   #1
Trailer: 1988 Scamp 13'
Hi there,
I ordered the 7" LED Bus Lights from Panther RV for my 1988 13' Scamp.
I have an extra wire because the new LED tail lights have three wires and the Scamp has four wires for the tail lights. I was looking at an old wiring diagram and it looks like the wire I'm not using in the Scamp is the "yellow" wire (although it changes to black right at the tail lights) which is the "stop light for foreign cars."
The new tail lights work great (don't worry about the picture, I'll solder the final connections and tuck them into the trailer...this was a test). However, what should I do with the extra wire? Cap it? If so, how would that be best done? Thanks for any thoughts!
mnimz is offline   Reply With Quote
Old 04-29-2017, 02:30 AM   #2
Trailer: 1980 18' Sunrader Motorhome and 1971 Trailswest Campster
Originally Posted by mnimz View Post
Hi there,
Just go to any hardware store or auto parts store and buy a crimp on end cap. It is a standard item found where the automotive wiring products are located.
Old 04-29-2017, 04:17 AM   #3
Borrego Dave's Avatar
Trailer: Casita SD17 2006
KCs answer is good but you could also just fold it over and use a couple rounds of electrical tape on the end to do the same thing. Just different ways to get it done.
Old 04-29-2017, 08:46 AM   #4
Trailer: 1999 Casita 17' SD
Ohio
Yellow wire is normally for backup lights.
Old 08-27-2017, 06:54 AM   #5
Ken Asprey's Avatar
I was wondering if the 7" round led tail light fits flat on the scamp?
Ken Asprey is offline   Reply With Quote
Old 09-18-2017, 06:16 PM   #6
Borden's Avatar
Name: Borden and Carole
backup light wire
Our boler has that wire was installed by manufacturer; but no lights added tested and it works so just need lights that will look ok under the original tail lights. Nice some manufacturers added this.
1978 Ontario made Boler
Old 09-18-2017, 06:58 PM   #7
When I went to led Scamps 4 wire threw me for a bit. The extra wire is for a back up lights so I mounted extra lights to the bumper. One other issue I ran up against was the need for a liscence plate light so I had to tie in an extra wire off the light circut and ground and hook a small led light over the liscence plate. Getting rid of the light bulbs and its poor contacts should make my lighting so much more relialble.
Old 09-19-2017, 08:35 AM   #8
Ohio
You could find some inexpensive automobile fog lights and mount then under your bumper and get good lighting
Here's an example only, not recommending
http://www.autoanything.com/lights/69A5643A0A0.aspx
I've gotten blasted because a person thinks the Timken bearings I linked too could be counterfeit
light
one wire led exterior light Bargman 99 chris 1 Problem Solving | Owners Helping Owners 10 08-08-2016 06:58 AM
yellow wire/brown wire deryk Electrical | Charging, Systems, Solar and Generators 24 01-01-2013 05:34 PM
Grounding Tail Lights with no White Wire Tim Bas Problem Solving | Owners Helping Owners 2 08-11-2010 03:27 AM
7" Round Tail Light Frederick L. Simson Classified Archives 0 12-14-2005 06:48 PM
need tail light Legacy Posts Problem Solving | Owners Helping Owners 8 04-12-2003 07:36 AM
» Virginia Campgrounds
Copyright ©2000 - 2017, vBulletin Solutions, Inc.
