Wiring for Compact II HELP!!!! PLEASE!!!! - Fiberglass RV
Old 05-25-2013, 05:53 PM   #1
Trailer: Compact II by Hunter
I am having some issues getting my trailer wiring to work and could really use some trouble shooting advise!! Issue: Mainly on the left side. Fading of the blinker if the running lights are on, sometimes the running lights don't even work (without changing the wiring, just seems finicky) No running lights the blinker works fine but the brake light is really dim compared to the right side. Occasionally, the right blinker will blink, dimly, when the left side is on, no consistency when running lights on or brake lights, just seems to randomly happen. Otherwise the right side works great with bright running light, break light, blinker or even all three together! Ekkkk I might just pull my hair out! This is really frustrating and any help would be greatly appreciated!
Dawnette is offline   Reply With Quote
Old 05-25-2013, 06:02 PM   #2
Thomas G.'s Avatar
Trailer: For Sale Or Rent
Rooms to Let 50 Cents
The most common problem with trailer light wiring is a poor ground. Run a temporary ground wire from your tow vehicle white wire (or shiny metal on the chassis) back to the light socket. If it works properly, then trace down the ground fault.
My preference is to not use the frame as a conductor, but to run a separate ground wire to each light. Also remove the bulbs and check/ clean the contacts on the bulb and in the socket with fine sandpaper or an emery board.
You may also have a problem at the plug. Have some one wiggle it around while you watch the tail lights. If they change, the plug may have poor connections.
Old 05-25-2013, 06:06 PM   #3
These types of things are often caused by poor connections. I'm not sure if your trailer was wired using wire for negative battery. I suspect that they used the frame for the negative side of the power to the running lights, brake lights (brake lights and turn signals are the same lights and wiring).
If they wired so the frame is the negative side there should be wires attached to the frame near every running light, and tail lights. Look for those connections first. If that's how it's wired the connections are probably corroded.
Old 05-25-2013, 06:33 PM   #4
Oh my gosh Tom you are a genius!!! The ground worked so we cleaned the connection to the bulb (how ridiculous of us not to think of this) found a tiny crack in the fixture that wasn't allowing the connection to stay consistent....long story short, I still have my hair AND we have lights!!!! Lots and lots of light!!! Thank you sooo much!
Old 05-25-2013, 06:40 PM   #5
There are bulb socket brushes available, Lisle is one company that makes them. Just don't try cleaning the socket with any lights on.
Old 05-25-2013, 06:44 PM   #6
Thomas G.'s Avatar
Good deal. Nothing more frustrating than being ready to go and no lights.
As I mentioned, if you run a ground wire from the plug back to one light then over to the other you will save yourself and any future owner many troubles.
Old 05-25-2013, 07:03 PM   #7
Thanks to everyone that replied and so quickly!! That's why I LOVE this site I hope everyone the best camping this season camp on fellow fiberglassers, camp on!!!
Compact/Compact Jr./Hunter, etc. owners POLL JenPB General Chat 22 03-17-2014 09:31 PM
Looking for a compact / compact jr or small fiberglass teardrop alan H Wanted: Molded Fiberglass Travel Trailers 5 09-15-2010 08:34 AM
Compact/Compact Jr./Hunter class owners JenPB General Chat 21 06-05-2009 02:10 PM
compact jr. & compact II Kent I Care and Feeding of Molded Fiberglass Trailers 4 08-21-2007 08:29 AM
WANTED A COMPACT JUNIOR OR COMPACT II IN VANCOUVER, B.C. Angela Mattice Wanted: Molded Fiberglass Travel Trailers 0 01-20-2007 01:19 AM
