wiring question... - Page 2 - Fiberglass RV
Old 02-29-2016, 09:14 PM   #15
John in Michigan's Avatar
Trailer: 1978 Trillium 4500
Originally Posted by spaghettiroad View Post
I assume the yellow in a 6 pin configuration was for backing up? My battery from what I can tell runs a black and red to the interior. The red connects to a 4 panel fuse plate; internal lights, sink pump and propane heater...
Yes, yellow in a 6-pin configuration is for backing up.
Concerning your battery (assuming its located in the trailer), color coding is red = positive terminal and black = negative terminal. The other standard is black = positive terminal and white = negative terminal.
Old 02-29-2016, 09:18 PM   #16
spaghettiroad's Avatar
Trailer: MITY LITE
External marine battery with red/black cable wires running into trailer. Black to be grounded to....and red connected to fuse plate I assume. Red tap wire to fuse plate and black grounded and same idea with lights and heater
spaghettiroad is offline   Reply With Quote
Old 02-29-2016, 09:26 PM   #17
Black/ground could be grounded through frame, but better to have black/ground wire run from battery back to each load.
Typically a 110vac to 12vdc converter/charger is also included in the trailer. When shore power is available this will power the 12v loads and charge the battery.
Old 02-29-2016, 09:37 PM   #18
Trailer: MITY LITE
Ok Thanks. I wonder if theat's what the metal box is,,,Have not opened it. External hook up runs into the box. Theres an on/of switch outside of box and 2 typical electrical wires running out from either side of box to standard plugs not set up yet...
Old 03-01-2016, 04:58 AM   #19
If you post some pictures of this box at various angles, someone might be able to provide insight.
Old 03-01-2016, 10:12 AM   #20
David Tilston's Avatar
This is likely a breaker box. The switch is probably labeled with 15, for 15A trip.
Old 03-01-2016, 12:17 PM   #21
Trailer: MITY LITE
Yes that's what it is. Thanks.
Old 03-25-2016, 06:09 PM   #22
Trailer: MITY LITE
Product
simple wiring question KarenW Problem Solving | Owners Helping Owners 10 08-02-2016 09:58 PM
solar hook up wiring question jimtesla Modifications, Alterations and Updates 3 05-07-2010 02:37 AM
boler wiring question Rick kl Problem Solving | Owners Helping Owners 1 12-13-2008 02:49 PM
7-pin wiring question Bonnie Problem Solving | Owners Helping Owners 3 07-28-2007 11:51 AM
Newbie Hitch Wiring Question Scott Bacon Problem Solving | Owners Helping Owners 5 06-01-2006 05:56 PM
