wiring trillium lights - Fiberglass RV
Old 07-09-2012, 05:47 PM   #1
Trailer: trillium
Nova Scotia
need help to wire trillium. anyone out there who has been through this problem? any diagrams available?
burns is offline   Reply With Quote
Old 07-09-2012, 06:28 PM   #2
Joe MacDonald's Avatar
Trailer: 1981 Trillium 5500
depends on the year and model, do you have a 13, 15 or 17 footer?
what do the lights look like on the back, do you have trailer brakes?
need to know these, to be able to help
joe
Old 07-09-2012, 06:51 PM   #3
Trailer: trillium
Nova Scotia
help wiring trillium
Thanks for reading my post. It's a 72 trillium, 13 foot without trailer brakes
Old 07-09-2012, 06:56 PM   #4
Trailer: trillium
Nova Scotia
Lights are about two years old and purchased from Princess Auto.
Old 07-09-2012, 07:05 PM   #5
Trailer: Class A Motorhome
Best Bet... Start from scratch, run new wires and make your own schematic as you go.
For the tail lights you can buy a Bargeman wiring kit, that will give you quality wires of the correct gauge for all the tail lights etc. as well as a common color code to use. I usually put a terminal strip right inside the front wall and wire to and from that point.
Old 07-09-2012, 08:28 PM   #6
Roy in TO's Avatar
If you are starting from scratch, even though the sale is over you might want to see this thread.
http://www.fiberglassrv.com/forums/f...2-a-52356.html
Old 07-09-2012, 11:24 PM   #7
Herb K's Avatar
Trailer: 1957 Teardrop
Check in the documents center on the left side of the home page, and then go to the bottom and open Trailer brand mfg, find TRILLIUM and look for the wiring diagram.
Herb K is offline   Reply With Quote
Old 07-10-2012, 08:55 AM   #8
What I have previously done: I installed plastic conduit (Water Pipe) under the camper and ran my wires in there. Very easy and it provides protection to the wires.
Old 07-16-2012, 06:41 PM   #9
the wiring to your lights should enter under the road side bench at the front, there are usually joints there, its a common place for a bad ground connection(usually a bunch of white wires under a crimp connector.)
From there wiring generally runs along the road side to the back where it meets the roadside tailight,(more joints) then across the back to the curbside taillight(more joints)
You may have to carefully peel back ensolite below the benches to access the connections.
Joe
Old 07-25-2012, 03:02 PM   #10
Alex C's Avatar
Trailer: 1977 Trillium 4500
Hey Roy, went down to Princess Auto and found that all the LED trailer lights that where on sale for $39.99 are sold out. That's 2 (two) days ago when I purchased mine. WOW they are sure popular.
Alex C is offline   Reply With Quote
Old 07-25-2012, 03:21 PM   #11
Roy in TO's Avatar
They sold out last sale as well, You should get a rain check Alex.
Old 07-25-2012, 06:26 PM   #12
David Tilston's Avatar
They are still available online.
lights, trillium
HELP- - Re-wiring a 74 Trillium 13' Barry Konkin Electrical | Charging, Systems, Solar and Generators 20 10-05-2015 08:35 AM
Wiring problems with trailer lights Rickholt Electrical | Charging, Systems, Solar and Generators 18 07-16-2013 02:34 PM
Need help in wiring up trailer rear lights alan H Problem Solving | Owners Helping Owners 19 06-12-2012 01:02 PM
Need help on wiring new side lights, old scamp Drew Bogner Problem Solving | Owners Helping Owners 6 07-18-2006 06:44 AM
Wiring Scamp tail lights Legacy Posts Care and Feeding of Molded Fiberglass Trailers 8 06-01-2003 08:50 PM
