yellow wire/brown wire - Page 2 - Fiberglass RV
Old 01-01-2013, 05:44 PM   #21
deryk's Avatar
New Jersey
Ok Jim, here is some photo's if you can tell if the batteries look wired correctly. Im not sure, its more involved then the battery setup on my boats.
thanks
deryk
Old 01-01-2013, 05:58 PM   #22
cpaharley2008's Avatar
It does not appear to be correctly wired. It appears the converter charge wires (+ and -) goes to one battery and then back fed to the other. This is not correct. You want the positive from the converter to one battery and the negative from the converter to the other battery. You then connect the battery positives with a cable and the battery negatives with a cable. This makes both being treated as one big battery.
Old 01-01-2013, 06:24 PM   #23
Francesca Knowles's Avatar
Trailer: '78 Trillium 4500
What???
Since when can't one connect both pos and neg to one battery and then connect that battery to the next in the series???
Francesca
Old 01-01-2013, 06:31 PM   #24
deryk's Avatar
New Jersey
Jim Im not sure. It looks like in photo 3, that they do the positive and negatives connected together but looks like all 4 battery terminals/posts are going off the charger...Im gonna have to ask Chandler what is going on.
thanks
deryk
Old 01-01-2013, 06:34 PM   #25
Thomas G.'s Avatar
I don't see a problem with the wiring, but if the battery hold down strap is original, I'd be a little disappointed.
What is Best Way to Wire to TV? barryra Modifications, Alterations and Updates 9 04-25-2011 02:00 PM
Re-wire Vicki A. Electrical | Charging, Systems, Solar and Generators 11 02-10-2010 03:07 PM
Yellow wire on 7 pin connector ? Mikeny Towing, Hitching, Axles and Running Gear 2 04-13-2008 01:22 PM
What is the yellow wire? Victor Benz Problem Solving | Owners Helping Owners 15 06-29-2006 01:30 PM
Yellow wire on 7 pin connector ? Mikeny Problem Solving | Owners Helping Owners 0 01-01-1970 12:00 AM
