Yet another PD4540 ques version 2 - Fiberglass RV
Old 06-12-2017, 07:46 PM   #1
Patricia D.'s Avatar
Trailer: 1975 Ventura
Manitoba
I had not noticed until today that there is an electrical section so I am reposting the thread I had put elsewhere in the hopes of even more feedback from owners who have used this Progressive Dynamics product.
I currently have no electrical in my trailer but I am going to install 12 and 120 v systems shortly. I eventually will be adding solar for most of my needs but want to be able to charge from shore power when it is available and at home.
I am going to buy a PD 4045 and my son, a Journeyman Electrician, will be flying here from BC to install my systems. But he is going to be doing it on the long weekend in July when many stores and certainly automotive and electrical suppliers will be closed.
I am hoping that one (or more) of the forum members who have used this panel and are experienced with electrical installations will kindly suggest other items we might need to do the installation. Even though he can access the online manual ahead of time, there may be quirks unique to the project that are not obvious from the reportedly poor instructions. Being able prepare beforehand would really help.
Thank you in advance.
Patricia D. is offline   Reply With Quote
Old 06-12-2017, 08:23 PM   #2
John in Michigan's Avatar
Hopefully a building supply store (for 110vac hardware) and an automotive supply store (for 12vdc hardware) will be open. For the 110vac circuits, you'll need to determine / purchase:
- 30 amp shore power cord, EDIT: 30 amp RV inlet, 15 amp to 30 amp adapter for connecting at home
- how many outlets wanted and how many separate circuits wanted
- desired rv outlet hardware
- length, gauge and type of wire (12 or 14 gauge multi-strand?) needed for outlet circuits
For the 12vdc circuits, you'll need to determine / purchase:
- battery, bracket
- suitable fuses for fuse panel
- how many separate circuits wanted for lights, propane detector (?), cigarette/usb charger outlet (?), etc
- length, gauge and type of wire (8 or 10 gauge multi-strand?) needed for wire from PD4045 fuse panel to battery
- battery fuse (30 or 40 amp depending of maximum DC load)
- length, gauge and type of wire (14 gauge multi-strand?) needed for DC circuits
- light fixtures, other accessories desired
Also you'll need some appropriate sized splice connectors and ring connectors for the 12vdc circuits. Hard to guess how many and where.
Probably more that I have missed here...
Old 06-12-2017, 08:31 PM   #3
Is the camper already wired with a towing plug and exterior towing lights (brake, turn, marker lights)?? If not, more parts and wire to buy...
Old 06-12-2017, 08:33 PM   #4
Other items to purchase:
- wire bundle covering
- wire tie downs/clamps
Old 06-12-2017, 09:58 PM   #5
Manitoba
Thanks so much, John. This is exactly the concise detailed information I was hoping for. I have the wiring for the lights and the plug. I am working on that wiring on rainy days when I can't work on my nemesis- repairing and painting the exterior.
I read on a post here about RV rated plugs for 120v system. Are these necessary or will residential plugs suffice?
Old 06-13-2017, 04:29 AM   #6
Trailer: Amerigo
Vermont
You will also need a bus bar that will hold the number of 12v circuits you will have, it does not come with the unit, just installed a PD 4135 in our 1973 amerigo. You will also need a main ac power breaker and breakers for each ac circuit you will have. I purchased all but the wire and breakers from Amazon and went to Lowes and an automotive store that were close to my home for the rest.
skpcat is offline   Reply With Quote
Old 06-13-2017, 04:35 AM   #7
Trailer: Amerigo
Vermont
My stepfather helped us with the install in our Amerigo and he was able to do all of the technical work and have it ready for us the install all of the plugs/lights/ect in about a day.
Old 06-13-2017, 04:58 AM   #8
Not sure what you mean by "RV rated plugs". You'll need to buy a water tight hull-mounted 30 amp inlet. The 30 amp shore power cord plugs into it. I believe there are two types: locking and non locking. Others can weigh in on preferences.
EDIT: You also need 10 gauge 3-conductor wire to connect the 30 amp inlet to the PD4045 main breaker. Normally the 110vac ground wire coming into the camper is fastened to the metal frame. Also note that the 12vdc common/negative wiring is usually NOT wired to/through the metal frame on a FGRV.
Old 06-13-2017, 05:07 AM   #9
- Battery box
Old 06-13-2017, 05:50 AM   #10
Originally Posted by John in Michigan View Post
- Battery box
Vented battery box if the battery is inside the trailer
Old 06-13-2017, 06:32 AM   #11
Manitoba
Is this the type of thing:
https://www.amazon.ca/Blue-Sea-Syste.../dp/B0091VHLW4
If you purchased fuses ahead of time, how did you know which to buy? Thanks
Old 06-13-2017, 06:40 AM   #12
Manitoba
"Also note that the 12vdc common/negative wiring is usually NOT wired to/through the metal frame on a FGRV."
This is the part that has me confused and prompted my original post. I read about the negative (white) wires going back to the charger but could not get a clear idea of what happens then. Is that the point of the busbar or , if not, what happens to those wires?
Old 06-13-2017, 06:40 AM   #13
Battery size
Typical battery size for your needs particularly if thinking about solar future is group 27 100 amp hour deep cycle
Old 06-13-2017, 06:43 AM   #14
110vac breakers and 12vdc fuses must match your pd4045 manual or label
Yet another PD 4045 ques. Patricia D. Problem Solving | Owners Helping Owners 4 06-12-2017 07:40 PM
Yet another towing question Greg Yother General Chat 16 04-11-2007 05:09 PM
Yet another alternative awning option Gina D. Modifications, Alterations and Updates 6 10-24-2006 09:46 AM
Yet another solar thread..... Lizbeth Electrical | Charging, Systems, Solar and Generators 6 06-08-2006 01:12 PM
Yet another glass camper??? General Chat 0 01-01-1970 12:00 AM
