Your battery recommendations? - Fiberglass RV
Old 07-08-2015, 12:07 AM   #1
Trailer: 1985 Scamp 16, 2013 VW Tiguan SEL
This is a simple question, perhaps unworthy of you electrickal wizards, but here goes -- I need to buy a new 12v battery for my old Scamp. Does anyone have a favorite battery choice or source? Why? Is the cheapest choice best, or should I be looking for something extra?
John McMillin is offline   Reply With Quote
Old 07-08-2015, 12:40 AM   #2
As with many things it all depends.
Because I camp close to 100 day at a time and off the grid a good true deep cycle battery is a good thing. I got by for several years with standard hybrids listed as marine deep cycle batteries. The difference is to me was most hybrids are 74 to 80 amp hour batteries, while my Trojan Deep Cycle battery is 100 Amp hour. Many people like to get AGM (Glass Mat) batteries, my take on those they're great for airplanes, but over kill for things that stay upright.
"Is the cheapest choice best"? If most of your camping is one of the following, I would say yes.
Most of your camping is where electricity is provided.
Your longest stay off the grid is a few days.
You camp about 2 to 10 nights per year.
All your camping is done in warm weather so the furnace seldom runs.
I'm sure there's other things.
That's my opinion and I'm sticking with it.
Old 07-08-2015, 05:25 AM   #3
Trailer: Escape 5.0 TA
W. Mass
Can only speak on 2.
I had 2 12 volt in parallel on my last trailer, an Interstate Deep Cycle group 24, and a similar Walmart. Bought them a year apart, the WM being the newer. Both were still working 8/7 years later although the gravity in the WM showed it didn't was starting to have issues. The only difference between the expensive one and the cheap one I noticed was the cheap one needed more maintenance. The water level dropped at least twice as much as the Interstate. The caps were mot nearly as tight on the WM.
If $ is a big concern and you don't mind taking care of it, the WM deep cycle was decent. If you'd rather spend more $ and get a better battery that takes less care and probably will last longer, go for an Interstate.
I probably hear the most praise for Trojans but find them hard to come by and over my budget. I have Interstates (2 @ 6V) on the Escape.
Bob & Deb
padlin00 is offline   Reply With Quote
Old 07-08-2015, 05:26 AM   #4
I'm not a battery or electric specialist like some here so can only go by experience. I have four trailers in my drive way with different battery set ups . The one with the best working battery and least maintenance is the agm battery I bought used for 80 bucks . It easily charges with the 40watt solar panel and always remains fully charged.
Mikmay is offline   Reply With Quote
Old 07-08-2015, 09:49 AM   #5
Trailer: Escape 17b 2006
AGM owner
I just bought a size 31 AGM its the largest I could fit into the battery box without doing some modifications. I have had it for a year but this is the first couple of trips that I have been on with it dry camping. I have monitored it with a volt meter the last couple of dry camps. After three days of liberally using all my accessories including my max fan I saw a drop from 12.8 v to 12.4 with a 5 watt solar panel. I understand that a critical discharge will go down to 11.9 v. After two days with no solar panel and using my maxx fan at night during the extreme temperatures we recently had in BC it was still reading 12.7.
I understand that these battery's will charge 4-5 times faster than a regular deep cycle. Which means I should have a full charge after driving for 4-5 hours which is realistic for me if I chose not to plug in I will have a fully charged battery when I get to my next stop.
They will also accept a charge faster while using a solar panel. I just bought a 25 watt upgrade but will see how that works through the next couple of years. I see that homes with solar systems use AGM battery's, the new Telsa solar electric vehicles as well.
They require no maintenance, they will withstand a lot of shaking so when I hit some those gravel roads it will not destroy my battery from all the shaking around.
Some marine applications have reported that they have had up to ten years service from one.
I also see that a lot of high end cars, and motor homes have started to use them.
At this point time will tell. I really don't want to be stuck with a dead battery as all the new fridges require a charge to keep the led panel on your fridge working. It goes out and so does your fridge.
That said they are not cheap, I paid close to $400 for mine through Canadian tire.
Grant Allen is offline   Reply With Quote
Old 07-08-2015, 12:32 PM   #6
IllAnnoy
I like WalMart's best deep cycle battery.
I have had good service from them, but the main logic is that the battery goes on my travel trailer. When I travel there is nearly always a WalMart nearby in case I need service or battery warranty replacement away from home.
Old 07-08-2015, 12:50 PM   #7
Trailer: Shopping for new RV
WALMART....simple warranty...a the batteries they sell are made by Interstate.
They do sell true deep cycle batteries....look for the units with removable cell caps so you can add water as needed. They also sell "maintenance free "deep cell marine batteries" do not buy any maintenance free units as they are not true deep cell units.
AGM batteries are hard to find and come at a premium price....mixed reviews on these....stick with Walmart...best price...full replacement warranty (save your reciept).
Note: measure the size of the compartment your battery goes into...it is a good idea to up-size your battery for longer life.(most travel trailers come with a group 24 size from factory). I moved from a group 24 size to a group 27 size....if I had the space I would have gone with a group 29 size as the additional cost to move up in capacity is less than $10 per-step.
Happy Camping
Uplander is offline   Reply With Quote
Old 07-08-2015, 01:36 PM   #8
Here's the Walmart battery I'm looking at currently (see link at the end of this post). It's the EverStart "MAXX" that has the 2 yr full-replacement warranty. As Floyd states, not many places you will go that does not have a Walmart. This battery is built by Johnson Controls located in Wisconsin.
The 690 is MCA (Marine Cranking Amps) and not CCA (Cold Cranking Amps).
I've studied up on these batteries some and the "capacities" ratings are all over the place. I have a Northern that's currently in my Scamp that states it has 140 RC (Reserve Capacity). SO, reading Mark Polk's information, you take that and multiply it by .6 (60%) and you get the actual capacity of the battery- so that would be 84A. Here's the article if you're interested that explains how they come up with the RC rating of a battery:
What You Need To Know About Your RV Batteries - RV Information (RV Maintenance)
Well, FWIW, I took a snap-shot of the top of the Walmart battery when I was out there and it says it's a 92 AH @ 1A. Meaning that you should be able to pull 1A out of the battery for 92 hours. Well gee...who else has this rating on it?
Anyway, enough confusion. Here's the battery I plan on going with because of the 2 yr warranty and the $99 price tag.
EverStart Maxx Lead Acid Marine Battery, Group Size 24DC - Walmart.com
Old 07-08-2015, 02:00 PM   #9
Raz
Raz's Avatar
Vermont
Only battery you can buy on line and UPS will deliver. My first one lasted 8 years and died a sudden death when the 12 volt element on the 3 way fridge was left on. I blame the dog. Sealed with virtually no off gassing. It sits in the basement all winter with no self discharge. You're quite right though they are pricey. $250 for a group 24 Lifeline. Raz
Old 07-08-2015, 03:33 PM   #10
Duracell agm deep cycle group size 34m $119.00 , group size 31 $179.00 available at SAMs club
Old 07-08-2015, 06:21 PM   #11
Larry C Hanson's Avatar
Trojan Endorsement
Hello,
I agree with Byron regarding the Trojan Battery....
I have had the Trojan SC225 for 6 years and it has
served well. I keep it on a battery maintainer when
not in use. My simple solar system of one 150W portable
panel and MPPT controller provide plenty of juice if the
sun shines. I have found that flooded batteries give
great service if treated and maintained properly.
I cannot recommend any WalMart batteries and do
not care for AGM batteries.
Good Luck,
Larry H
Old 07-08-2015, 08:59 PM   #12
Costco Group 27 Deep Cell has been going strong for 5 years now with lots of time spent camping off the grid. Use a simple solar system that works well at keeping it full.
Old 07-08-2015, 09:39 PM   #13
92 AH @ ! amp. WOW... Most batteries are rated at XX AH @ 20 Amp.
Useable is 1/2 or 50% of rated capacity. That would mean your 92 AH @ 1 Amp is good for 46 hours.
Marine batteries are hybrids. Somewhere between a cranking/starting battery and a deep cycle battery.
Old 07-08-2015, 10:24 PM   #14
The problem with the 92 AH @ ! amp rating is there's no correlation to the standard 20 amp method. Is it better or worse than the 74 amp hour @20amp rating of most batteries?
battery, eco
Looking for battery recommendations billhenry58 Electrical | Charging, Systems, Solar and Generators 0 07-02-2013 09:29 PM
Battery Recommendations for a new UHaul owner? knighth001 Electrical | Charging, Systems, Solar and Generators 26 01-02-2013 09:00 PM
Maybe we can help, in your travels, keep your eyes peeled Mike Montville General Chat 0 03-24-2008 04:03 PM
Would your loan out your egg? MyronL General Chat 99 12-06-2007 05:55 PM
How do you place your microwave in your RV. Legacy Posts Problem Solving | Owners Helping Owners 12 02-07-2003 01:41 PM
» Trailer Showcase
Casita
Poiny
Babie
Naomi Payne
