13' Scamp Water system diagram - Fiberglass RV
Old 08-26-2009, 03:06 PM   #1
Wilder's Avatar
Trailer: 1993 Scamp 13 ft
Hi,
My wife and I just bought a 1993 13' Scamp last week. I have a question on the water system. The pump turns on, but doesn't seem to build up pressure. I hear some gurgling out of the faucets when open, but nothing comes out. I haven't pulled the pump yet to make sure it is pumping, but in looking at the plumbing, something looks odd to me. Attached is a sketch of the way the system is plumbed. The pump is connected to the supply lines for both the faucets, but I'm not sure which one is the IN and which is the OUT connection to the pump. But it just doesn't seem right. We bought it from the original owner who said it is mostly stock (and it is in very good condition), but I'm wondering if someone maybe replaced a water line or something and put it back together wrong. Can someone please take a look at this diagram and let me know if it is the way it was intended?
Thanks!
Wilder is offline   Reply With Quote
Old 08-26-2009, 05:27 PM   #2
The pump should be on the line from the tank, BEFORE any faucets.
On your drawing you have it between the faucets and if you have the one on the left open you will suck air.
Bill K
Hi,
Thanks!
Old 08-26-2009, 05:29 PM   #3
Robert Johans's Avatar
Trailer: 1988 Scamp 13 ft and 1982 Perris Pacer 13 ft
I believe your pump should be between your tank and your first faucet. And makes sure you have a check valve of some kind between your city water intake and your holding tank. If you don't, the pressure from the city water source will backfill your tank to excess and overflow.
Old 08-26-2009, 06:31 PM   #4
Wilder's Avatar
Thanks to a private message from another member, I have discovered the "faucet" on the left is actually a hand pump. So this changes things completely...off to investigate further...
Old 08-26-2009, 07:52 PM   #5
Wilder's Avatar
Ok, so I've updated the schematic - things changed when I found out the left side was a hand pump. I did find the 12V pump was plumbed backwards (maybe the PO replaced the pump just before the sale and put it in backwards). Also, the check valve on the city water inlet is broken, so I will replace that. But looking at it now, everything should work correctly once I get those items fixed. See attachment for updated diagram.
U-haul VT-16 Water system Matt in SV Plumbing | Systems and Fixtures 6 05-17-2010 08:17 AM
Help with wiring diagram setup DannyH Problem Solving | Owners Helping Owners 6 12-16-2009 10:02 AM
Losing prime in water system Paula D. Plumbing | Systems and Fixtures 19 06-07-2006 12:58 PM
Help adding a 12 volt system to a scamp 13 UncleJosh Electrical | Charging, Systems, Solar and Generators 10 03-31-2006 09:30 PM
Water system jefh Care and Feeding of Molded Fiberglass Trailers 6 01-17-2006 02:27 PM
