Accumulator tank? - Fiberglass RV
Old 04-27-2012, 09:42 AM   #1
Trailer: Bigfoot 17, 1988
Wisconsin
Accumulator tank?
Anyone use one of these? I'm wondering whether anyone thinks it is a worthy addition to the plumbing system. It makes sense to me, based on my experience with compressed air systems. I can't imagine trying to use an air compressor for anything except pumping up a tire without an accumulator tank.
Thanks.
pindraak is offline   Reply With Quote
Old 04-27-2012, 10:51 AM   #2
Trailer: scamp 13
Thanks.
does your plumbing system use compressed air?
Old 04-27-2012, 11:04 AM   #3
Wisconsin
I am making an honest attempt to find some info here. If you have some personal issues that require you to post compulsively and deride others, please choose another thread.
Old 04-27-2012, 11:20 AM   #4
Raz
Raz's Avatar
Vermont
I installed one on my last trailer. It allows you to run a slow trickle from the faucet without having the pump shake itself apart. Unlike my household tank, it was too small for storage or to maintain pressure for very long. Raz
Water Pump Accumulator Tank - PPL Motor Homes
Old 04-27-2012, 11:53 AM   #5
Trailer: scamp 13
i am trying to find out if you have a pressurised system that runs on air. otherwise what sort of accumulator are you talking about?<_<
Old 04-27-2012, 11:55 AM   #6
Trailer: scamp 13
is that like a pressure tank on a well? where there is a bladder inside ?
Old 04-27-2012, 12:14 PM   #7
Raz
Raz's Avatar
Vermont
Hi John. Yes, a much smaller version. See my previous post (#4) for a picture. Raz
Old 04-27-2012, 12:26 PM   #8
honda03842's Avatar
Name: Norm and Ginny
Accumulator
I installed a 2 gallon accumulator in our motorhome. It permitted you to use the bathroom at night without the pump running and reduces the number of times the pump turns on.
It worked well but I would probably not install another, even in the motorhome where their was plently of space. I installed mine under the bathroom sink in the coldwater line. It provided water thru out the trailer.
It does have an air bladder. As well they are very easy to install.
Norm and Ginny
2014 Honda Odyssey
1991 Scamp 16
honda03842 is online now   Reply With Quote
Old 04-27-2012, 01:01 PM   #9
Trailer: scamp 13
ok i see then, there is trapped air in the tank that maintains pressure. i have seen systems where an air chamber powers the water supply, but didn't think that system would fit in an rv, they are pretty bulky.
Old 04-27-2012, 01:37 PM   #10
Thomas G.'s Avatar
Trailer: For Sale Or Rent
Rooms to Let 50 Cents
I made a small one out of a piece of PVC pipe for my UHaul, as it uses an on demand pump. As Raz says, it allows a trickle from the faucet.
Old 04-27-2012, 06:07 PM   #11
Perry J's Avatar
Trailer: 16' Casita
I don't mean to offend your sensitivitys but my first thought was does his system work on air pressure.
John
Old 04-28-2012, 07:39 AM   #12
Wisconsin
John
I see now. The way the reply was written, it looked like a drive-by insult. I was making an analogy between a small pump hydraulic system working with air to one using pressurized water. The reply seems to be ridiculing this analogy.
The accumulator does use an air bladder, but the point is whether you want some kind of buffer tank so that the pump doesn't have to come on every time you use a little water. I was thinking it would be nice for showers and dishwashing, with frequent on/off.
Old 04-28-2012, 10:57 AM   #13
Trailer: Fiber Stream
I think adding an accumulator tank was one of the best parts of modifying my water system.
I wound up replacing the pump and adding the accumulator, separate particulate filter, and flexible hoses.
ID:	45542 Click image for larger version
When I 1st bought the Fiber Stream the original water pump sounded like a Semi's Jake Brake.
After repositioning the pump mount to allow the added components to fit in the now tight space, I cannot hear it operate at all.
Old 05-01-2012, 08:57 AM   #14
Wisconsin
Thanks. I am considering Whisper King. Is that a Shur flo or Flojet accumulator?
Istalling my FW tank Russell A General Chat 6 07-11-2011 11:18 PM
Added FW tank Russell A Modifications, Alterations and Updates 1 07-02-2011 07:22 PM
Accumulator Tank Lainey Care and Feeding of Molded Fiberglass Trailers 1 08-08-2008 04:33 PM
Water Pressure Accumulator Steve L. Modifications, Alterations and Updates 2 11-24-2005 03:32 PM
Water Pressure Accumulator Legacy Posts Modifications, Alterations and Updates 19 03-19-2003 07:24 PM
