Adding a camp stove to my LP gas regulator - Fiberglass RV
Old 03-21-2016, 08:43 PM   #1
Trailer: 1984 Scamp 13'
Nebraska
Hello all. I'm thinking I'd like to be able to connect a campsite stove to my LP tank on my scamp 13. Seems like it might be convenient to cook out side on occasion. Trying to find a regulator that has connections for two appliances.
Anyone done this or know of a regulator like this.
JD Eben is offline   Reply With Quote
Old 03-21-2016, 09:06 PM   #2
tractors1's Avatar
Trailer: Escape 21 - Felicity
Escape trailers have a "T" fitting in the line coming from the regulator to the trailer appliances, routed out under the passenger side of the trailer. That's terminated with a quick disconnect valve, shown in the pic next to the steps.
You will have to take off any existing regulator on your stove as two in series will not work.
Charlie Y
Old 03-21-2016, 09:41 PM   #3
Anne H's Avatar
Trailer: Escape 17 ft 2006 / 2005 Honda Pilot
Does anyone know if there's an adapter or a way to circumvent the regulator on a Colmane grill so that you can use the Escape propane connection?
Anne H
Anne H and Fay Wray, the cat | Portland, OR
en Plein Air (2016 19' Escape; 2016 Honda Pilot )
https://rightbrainrightlane.blogspot.com/
Anne H is offline   Reply With Quote
Old 03-21-2016, 09:45 PM   #4
Go to Tractor Supply or Northern Tools and get a T adapter and hose.
Old 03-21-2016, 09:45 PM   #5
tractors1's Avatar
Anne H
You just unscrew the regulator and add a hose to plug into the disconnect on the trailer. If you need any fittings to make it work you can buy them at both Lowes or Home Depot.
Charlie Y
Old 03-22-2016, 07:38 AM   #6
We use a Coleman Roadtrip grill, and connect it to either a 20 or 11 lb tank using an adapter hose. I've found that some of those adapter hoses are not compatible with the Coleman regulator. First thought it was the regulator, but bought a new hose from Walmart and now it works. Had the same problem with an identical grill of my daughters, new hose solved the problem. Someone else had the same problem, and I may have read it here. I had made up a T fitting with a gas valve to tap in to the single tank on another camper but no longer use it as we wanted the grill farther away from the trailer. Now use a short hose connected to the tank which sets on the ground. Note that a tank setting on bare ground will eventually rust and pit underneath, making it unsafe to use and it won't pass inspection.
Old 03-22-2016, 09:34 AM   #7
Prior to the regulator
We do most of our cooking outside. Our RV place has an adapter that splits the unregulated output at the bottle, one side of which can then be connected to our Coleman stove which has its own regulator. Seems pretty simple and also allows the flexibility of running the stove on another, smaller tank.
Randy J. is offline   Reply With Quote
Old 03-22-2016, 09:58 AM   #8
Trailer: 13' 2008 Scamp...YAY!
Won't a propane "tree" do that same thing? Looked at them but now sure if it's something I'd have to attach each time. Apparently they will allow several connections?
Mon
monB is offline   Reply With Quote
Old 03-22-2016, 11:34 AM   #9
Trailer: 2014 13' Scamp -standard w/ front bunk
Vermont
JD,
We also prefer cooking outside. Rather than running a hose from the scamp's tank (our preferred cooking spot isn't always close) we carry a small one gallon propane tank that is light and easy to move to the cooking area. It readily hooks up to a coleman stove or small propane grill. It can be filled at any location that fills the 20 lb tanks. Here is a photo showing it mounted on the scamp hitch adjacent to the battery and behind the main tank. Easy on/off with two turnbuckles.
Not what you asked I know, but perhaps a useful alternative.
david
WDavidG is offline   Reply With Quote
Upgrading to two stage propane gas regulator Courier 3.2 Problem Solving | Owners Helping Owners 6 05-23-2015 05:28 PM
Single gas tank regulator - Scamp ShelleyZen Problem Solving | Owners Helping Owners 2 08-13-2013 10:54 PM
What signs that a gas regulator needs changing? TonyB Problem Solving | Owners Helping Owners 1 04-17-2009 06:47 PM
Pinhole in Gas Pressure Regulator? Daisy Problem Solving | Owners Helping Owners 3 10-16-2006 09:01 AM
