Aftermarket Outside Shower? - Fiberglass RV
Old 06-13-2018, 02:50 PM   #1
Trailer: 2016 17' Spirit Deluxe
Question Aftermarket Outside Shower?
Hi, all. I am about to purchase a 2017 Casita 17'SD. It has no outside shower. Is it possible to install one? Do you have any recommendations? Thanks in advance.
Alli is offline   Reply With Quote
Old 06-13-2018, 06:23 PM   #2
This is the same unit they install from the factory as an option, (first link.) It is mounted in a through-hull cut-out under the front side dinette seat base cabinet on the SD models. Ties into the existing hot and cold water lines running along the floor. These are pics of the one installed in my trailer. I replaced the H&C mixing valve that comes with it with this aftermarket one that has a quick disconnect for the hose, (second link.) You'll need the quick disconnect fitting to attach your garden hose to, (third link.)The hose/nozzle that comes with the factory unit is not very good and kinks a lot. I bought this coiled hose to use with mine, (fourth link.)
Rv Outside Shower - White
https://www.amazon.com/dp/B002P2YGHE...iglink21057-20
https://www.amazon.com/Phoenix-9-SA-...SIN=B003HK57T4
https://www.amazon.com/Phoenix-PF267...1Z17N062C4JPPE
Old 06-13-2018, 09:48 PM   #3
Thumbs up
Fabulous!! Thank you so much, Greg. This is extremely helpful. Thank you for taking the time to explain it so clearly and provide the links.
Old 06-14-2018, 07:41 AM   #4
You're welcome. Hope you enjoy it.
Greg
Old 06-14-2018, 12:20 PM   #5
Trailer: Sprinter 'til I buy
Denver, CO
Greg, I had the same reaction. You were very helpful.
Tom 72 is offline   Reply With Quote
Old 06-14-2018, 02:58 PM   #6
USDM's Avatar
Trailer: UHAUL
I highly recommend going with an ice fishing tent for the shower/bathroom. I did this with my Uhaul ct13.
85 Uhaul VT16
84 Uhaul CT13
USDM is offline   Reply With Quote
Old 06-16-2018, 04:35 PM   #7
Kai in Seattle's Avatar
When we use our privacy tent as a little bathroom, it does give us more privacy and space inside Peanut...works fine for showering (sit down showers, granted). Some days we can even heat the water with solar power in an all-black bucket...
An ice-fishing tent might be super for such a thing. Or a hunting hide type pop-up--very small windows.
Something to consider!
Kai
Semper ubi sub ubi.
Old 06-16-2018, 09:45 PM   #8
One caveat, using an outside shower, even if hidden from view in an enclosure, can be a big no-no in most parks. Direct discharge to the ground is not an approved method of disposing of grey water in a camp site. You may find yourself in trouble if detected using this showering method.
Old 06-18-2018, 06:02 PM   #9
Casita Greg: you are 100% correct.
I only use that situation when absolutely necessary...though I'd have a hard time claiming it is life saving to do so under any circumstances.
And I use a minimum of water; mainly I wash my hair, wetting it with one large plastic tumbler of warm water, using a minimum of soap, rinse it with another large tumbler of warm water, and that's it. The rest is just rubbing and run-off. I use the campground showers whenever possible--in Oregon, they have free showers and usually they work great.
Something to definitely keep in mind. Some campgrounds practically if not literally forbid putting any water outside...we'd have to respect that, for sure.
Gone are the days Peanut was made for--the original sink drain was a little pipe that emptied onto the ground underneath the trailer--there was no built-in holding tank for gray water designed for amerigos in those days of skies darkened by pterodactyls. Ah, such a simpler time! (Later there were those free-standing turquoise tanks, but that's another issue.)
And fewer people making messes in campgrounds...
Kai
i
Semper ubi sub ubi.
Old 06-18-2018, 08:12 PM   #10
Trailer: Trails West
In the area where you put the outside shower fitting add a small awning with side curtains. It is a discreet looking shower room that does not scream "portable toilet tent". It won't set off any alarm bells with the people who run the campgrounds or with any of the neighbors either. If the awning room is large you can partition off a corner of it for the shower and leave the rest for normal use. Just pull the shower curtain, meaning a sunbrella type fabric not an obvious shower curtain, around that corner when privacy is wanted.
I have opted to have a 5 x 5 popup canopy against the wall by my trailer door. I am making side curtains for it that have screened openings and roll down privacy/rain panels over the screened areas. Of course also a zippered opening against the trailer door as well as an exit door.
Of course if you are camping on Padre Island along the shore there won't be any issues with using an outdoor shower. Primitive camping is much more likely to accept it as a given, especially at the sea shore or lake shore.
Old 06-18-2018, 09:13 PM   #11
Thanks so much for all the replies. I've decided to go with a Casita with a built in shower both inside and out.
Old 06-23-2018, 10:50 AM   #12
Trailer: Phoenix
We use a Clam Shelter for our outside shower. Have tested it up to 60 MPH (NO JOKE!) winds @ Lake Havasu.
This: https://www.amazon.com/dp/B00TMBEMQ6/
Plus 4 of these panels (note that the 4th panel doesn't have attaching points like the other 3 but still loosely works): https://www.amazon.com/dp/B00YSPKZH6/
Cross-Threaded is tighter than Lock-tite
ntsqd is offline   Reply With Quote
Aftermarket items socks Problem Solving | Owners Helping Owners 0 08-17-2015 02:35 PM
Aftermarket Tow Hitch - 08 Highlander Hybrid? Anne in NW Towing, Hitching, Axles and Running Gear 3 04-25-2014 07:09 AM
Aftermarket Wheels.. "Let's See Em " Phil Underwood Modifications, Alterations and Updates 73 07-16-2013 09:12 PM
Dealer or aftermarket towing package? Ron Stewart Towing, Hitching, Axles and Running Gear 9 03-22-2009 10:40 PM
AfterMarket Air Conditioning Pete Dumbleton General Chat 4 01-03-2006 12:05 AM
