Anode rod - Page 3 - Fiberglass RV
Old 08-19-2015, 01:44 PM   #29
minke's Avatar
Trailer: looking
Originally Posted by steelypip View Post
... the solubility of the mineral salts decreases as the water is heated. ...
Thanks for the response. My geriatric memory of high school chemistry retained the over-simplification: solubility increases with temperature. As a result I read https://en.wikipedia.org/wiki/Solubility#Temperature and was corrected. Again, thanks,,,
minke is offline   Reply With Quote
Old 08-19-2015, 04:21 PM   #30
CPW
CPW's Avatar
Trailer: 2015 Escape 5.0TA
Anode rod
Originally Posted by Darwin Maring View Post
Steely pip is correct should th rod be totally isolated from the tank but I suspect that the Teflon fills in the gaps between the threads and that the threads actually contact making an electrical path. I will use an OHM meter the next time I insert the rod to see if I'm correct in my theory.
You are. I have already done that and there is continuity between the threaded plug and the rest of the water heater. I test with a meter every time I remove and replace the anode using Teflon tape.
Old 08-20-2015, 08:54 AM   #31
Alf S.'s Avatar
Trailer: 2014 Escape 5.0TA / 2010 Nissan Frontier
Hi: All... I never thought about continuity. All I know is that after the struggle to get that rod out when new and drain/rinse the tank, I didn't want to use that much force on it again.
The Teflon takes care of the drip!!! (Me)
Old 08-20-2015, 10:34 AM   #32
Trailer: 1992 Casita Spirit Deluxe
Virginia
I've seen both outcomes with the tef tape. My solution is to use joint compound instead.
steelypip is offline   Reply With Quote
Magnesium Anode Rod or Aluminum? Kevin K Care and Feeding of Molded Fiberglass Trailers 4 04-23-2012 08:36 PM
Anode Rod for heater.. Christi V. Care and Feeding of Molded Fiberglass Trailers 4 04-20-2008 09:25 AM
anode rod JHJohnson Problem Solving | Owners Helping Owners 2 08-07-2007 07:59 PM
An ideal anode removal tool Legacy Posts Modifications, Alterations and Updates 4 10-28-2002 01:38 PM
Anode Rod winterizing question? Legacy Posts Care and Feeding of Molded Fiberglass Trailers 15 10-18-2002 09:03 PM
