Atwood drain plug leak - Help! - Fiberglass RV
Old 06-27-2014, 11:18 AM   #1
Trailer: bigfoot
Saskatchewan
Hi,
While flushing out our Bigfoot recently, the brass petcock / drain plug started leaking (from the valve). I purchased a new brass petcock, but on removing the old one I can see that the female threads on the Atwood are a bit corroded. I could not get the new petcock to seal, and subsequently broke the handle off it too. I have now purchased white plastic plugs to replace the brass petcock. I screwed a plug in all the way with a socket wrench, but it still has a small drip.
Can I use teflon tape or dope on a plastic plug? I tried searching and did find a reference to mylar tape being used, will this help and where can I find it?
Thanks!!!
spartacus is offline   Reply With Quote
Old 06-27-2014, 12:02 PM   #2
tractors1's Avatar
Trailer: Escape 21 - Felicity
Easiest fix is to buy a steel plug, then use a hacksaw to cut a couple of grooves in the thread so it acts like a tap to clean out the corrosion. Of course the best would be to buy a real tap.
Then you could put a real drain plug back in.
Charlie Y
Charlie Y
Old 06-29-2014, 02:16 PM   #3
Trailer: bigfoot
Saskatchewan
Thanks for the advice. The threads have corroded away in spots, so it's not really a matter of cleaning the threads out. I have had success in using a white plastic plug and some Pro-Dope instead of teflon tape.
Old 06-29-2014, 02:32 PM   #4
Bob Miller's Avatar
For "Future" reference, there are special, oversize, plugs available with self tapping ability that will clear the old threads of cr@p while inserting them.
Often it's the rust particles in the threads that cause leaks and a good cleaning of the threads and chasing with a pipe tap usually results in a tight seal.
You might want to rethink that plastic plug. Unless it's rated for "Boiler use" it may not like the heat.
Old 06-29-2014, 02:41 PM   #5
Trailer: bigfoot
Saskatchewan
Thanks. I will pursue this further as I would much prefer to have a petcock style plug than the standard plug.
The current plastic plug is an Atwood replacement part, so I'm confident that it is heat suitable.
Old 06-29-2014, 02:41 PM   #6
NW Wisconsin
Atwood water heaters come with a nylon drain plug .The brass drain you installed may have reacted with the metal used in the tank and caused the tanks threads to corrode away .
Old 06-29-2014, 04:34 PM   #7
Bob Miller's Avatar
There are nylon "Boiler Drains" available at most plumbing and big-box stores. I have one on the 15+ year old Bradford-White water heater I just replaced. The tank was leaking, but not the nylon drain valve.
Old 06-29-2014, 05:18 PM   #8
papa-t's Avatar
Glade Valley, North Carolina
Spatacus did you use plumbing tape with the petcock style plug?
papa-t is offline   Reply With Quote
Old 06-29-2014, 07:35 PM   #9
Trailer: bigfoot
Saskatchewan
Thanks, I will be looking for one of those.
Yes – I had wrapped both threads (the petcock came in two pieces which threaded together then into the water heater). Admittedly, I was worried about over tightening the brass-into-aluminum threads. Then I broke off the petcock handle with the pliers (couldn’t fit a socket over the petcock handle, and no room for a wrench due to the gas line) while tightening it.
Old 06-29-2014, 07:41 PM   #10
papa-t's Avatar
I just installed a petcock drain on mine. I used tape on both but put in a vise and tightened the smaller outer one first. I used a short wrench to tighten into water heater. Had to use very short tiny strokes but finally snugged it down.
Old 06-29-2014, 07:46 PM   #11
Trailer: bigfoot
Saskatchewan
Good idea, I probably should buy some stubby wrenches.
2004 Trillium Outback Drain Plug for Water Tank? BarbinBC Problem Solving | Owners Helping Owners 5 09-08-2013 06:41 PM
Plug with camper doesn't work properly help needed please Mcmarkrazz Towing, Hitching, Axles and Running Gear 12 08-18-2013 02:08 PM
Atwood Fifth Wheel Jack - Electric Motor instead of Hand cranking Gail Shook Care and Feeding of Molded Fiberglass Trailers 12 07-31-2013 06:26 AM
gray water drain leak Tom Smayda Problem Solving | Owners Helping Owners 1 06-13-2013 01:58 PM
Help, I need a chicken and a drain flap flatfendershop Plumbing | Systems and Fixtures 16 04-15-2011 05:34 AM
