02-22-2015, 12:36 PM
Trailer: Own a 2013 BF 21 foot.
Bigfoot plumbing leak
Hello, have a 21 foot rear bedroom and wondering about what appears to be slight leak. In bathroom under window at the floor is a ledge cover about 2.5 feet. When done showering slight water appears at bottom of cover. Any ideas? Plumbing schematic? Trying to attach photo, thanks.
David
Slab city
02-22-2015, 06:58 PM
Plumbing schematic might just that - a schematic. Can you somehow trace the actual lines and expose them? Doing as little disassembly as possible? Showering may throw water everywhere. This requires a carefully controlled test.
02-22-2015, 07:13 PM
could have a pipe joint leaking while shower is operating, can you cut an access hole?
Jim
Never in doubt, often wrong
02-22-2015, 07:18 PM
Cutting is the next step. Hope to get a diagram of the plumbing before i start.
02-22-2015, 09:13 PM
Is it possible that the ledge cover is not intended to be watertight but only to protect the plumbing pipes from damage and to prevent the pipes from freezing
02-22-2015, 09:24 PM
It's possible but there is dampness where cover meets the floor.
02-22-2015, 09:45 PM
Maybe water is leaking behind the cover on the top seam and draining out the bottom seam
Usually the top seam is sealed/ caulked and the bottom seam is left open for drainage
This is just an educated guess but if a pipe sprung a leak there would be water seeping out any time the system was under pressure not just after showering.
02-23-2015, 09:27 AM
Trailer: Scamp 19
If it is cold...it could be condensation. I have seen this in our Scamp 19, side bath. There is an overhang and the vertical surface collects condensation if it is cold out and heated in. Just a thought.
02-23-2015, 09:38 AM
Interesting, water seepage is not hot. Guess I'll just keep an eye on it before tearing things apart. Wish I had a diagram of what's behind that cover.
David
Slab City
02-23-2015, 02:45 PM
if it's an RB....
first go through the bottom of that wardrobe....probably a removable panel in there...where you'll probably find hot, cold and drain lines running through there from the bathroom......just I wild guess....(using a mirror you might even get a view into the bathroom portion)...
02-23-2015, 03:14 PM
If the pump is on and there are no leaks until showering it sounds like something is leaking between the mixing valve and the shower head or something in the drain system. If you take a large bucket turn the shower head on (hot & cold) and discharge the water into the bucket preventing all discharge from going down the drain and you still have water on the floor, it's not the drain. You could also dump a bucket of water in the shower floor with the shower off, and if the floor is still dry it's not the drain.
05-07-2015, 05:55 AM
Name: ginette & ron
Trailer: 2008 25RB 21 Bigfoot
Just opened that panel in our Bigfoot. Ther is the drain pipe from the washbasin and water lines.
Our leak was minor. The oversized facet in sink had a loose aerator so water was coming down through the fixture and leaking out under the floor panel.
Need to find a smaller facet for the sink. The facet that is there takes up half the sink.
GiRo proud new owner 2008 bigfoot 21'with cargo pod and Ram 1500 Ecodiesel. Attached with a Pro Pride Hitch(Hensley design)
05-07-2015, 06:07 AM
Good information by all, thanks. I'm in Texas currently without the trailer but returning home soon and will tackle this leak. I see this more as a challenge than as a problem. Thanks again.
David
