Bigfoot sewer and water - Fiberglass RV
Old 03-02-2016, 04:24 PM   #1
ZachO's Avatar
Trailer: 91 Bigfoot 17
Montana
I have been and will continue to look at videos and search stuff online, but humor me if you want...
This is my first time with a camper that has sewer, a water pump, and a water heater and shower. I've been checking out some videos and reading some threads here, but if anyone has any advice specific to Bigfoot that might be different or unique, or just in general wants to give me some advice on how it all operates and tips/tricks, that would be cool. Like where I should be looking for drain hoses on my camper to make sure it even has everything I need to be fully functional.
Some of the specifics I'll have more questions on once I get out and try to do this stuff, but I figure the more I can learn leading up to actually using any of those systems, the better...
Old 03-02-2016, 08:09 PM   #2
Trailer: 28' Bigfoot Silver Cloud
Oak Park, IL
We'll be in the same situation when we pick up our Bigfoot Silver Cloud in six weeks! There will be lots of questions, for sure.
Old 03-02-2016, 09:28 PM   #3
Tom Trostel's Avatar
Trailer: 1980 Bigfoot 17 ft
The Rhinoflex 15' sewer hose, complete with the white, 90 degree elbow, will fit into the rear bumper of my Bigfoot.
http://www.amazon.com/Camco-39761-Rh...lex+sewer+hose
Old 03-03-2016, 03:02 AM   #4
Borrego Dave's Avatar
Trailer: Casita SD17 2006
Zach is doesn't matter if you have a million$ Provost or a 30 year old trailer, the sewer hook ups and operations are the same. I like the Rhinoflex hose as it seems to be a bit tougher than the cheapies. Empty the black tank first, then the grey as it kind of cleans the hose from the black drainage. Still have to rinse it but not as much. If you have full hook ups, leave the black tank valve closed as you need the volume in it to complete the emptying the solids in it. The grey can be left open but I would keep it closed and use it's contents to flush the hose after opening the black tank. Don't over think it, it's not rocket science. Don't know if there is any quirks for your trailer but on a Casita the grey tank can take a longer time to empty than most.
Old 03-03-2016, 06:07 AM   #5
I converted our Casita hot water tank to electric. Almost 4 months of steady use now and very happy with it. Dave, I was told by another Casita owner that the vent kit from LHC helps the grey tank drain quicker.
Old 03-03-2016, 06:41 AM   #6
Gilles's Avatar
Trailer: Bigfoot 15B17G, 1986.
Quebec
The past year I bought my first trailer with sewage and camping companion had spoken of "Sewer Solution" saying he was very satisfied.
I bought a kit of 3 inches. I have not even used once, still new.
I bought the "Sewer Solution" began to use and I love, even if it is not the hottest moment of my day, but it makes it more acceptable, especially when I see other campers, who have the big pipe work.
Watch the video, it shows very well how. I admit I was skeptical at first, but I soon found out the obvious.
With my Bigfoot 17', I had to buy the 3 inches extension, I think 12 inches long, to properly remove and elbow 3 pouces / 45 , because my original Bigfoot and low axle.
The kit contains a hose 10 feet, to which I will add an extension of 10 feet, I can buy separately. With 10 feet additional, occasionally it would be better in certain locations ...
Some videos that show this system, explain that when you put pressure system to the inside, that this gesture cleanses residues laying in the bottom of the black water tank, which is not the case .. .
It remains to add, as shown in the video, the second hose that is used to clean the black water tank.
Look the video and observe :
Sewer Solution - Valterra SS01 - Drain & Flush Systems - Camping World
Gilles
Bigfoot 15B17G.
Towed with Dodge Journey 2012, 3.6 L., 6 speeds.
Old 03-03-2016, 08:27 AM   #7
ZachO's Avatar
Montana
Wow, that's pretty nice. So I guess the water hose that hooks in breaks up larger...chunks...so that they can fit down the more narrow drain hose? That looks like a really good thing to have. I guess I'll need to use my camper a bit before I decide on something like that, since it's kind of expensive. I start working again in May, so I'll be able to think more seriously about stuff like this.
Thanks!
I know I've got a sewer hose in the bumper, I'll check to see what it is. Will it say Rhinoflex on it? Or how will I know if mine is "cheap" or not?
Old 03-03-2016, 09:37 AM   #8
Trailer: Bigfoot 17' DLX
Alaska
As others have said, sewer hookups are pretty universal from RV to RV. The best advice I can give specific to a Bigfoot, especially an older one with a steel bumper, is to slide a section of PVC rain gutter material into the bumper after you've pressure washed it out as best as possible. The inside of these bumpers rust badly and the scale will tear a sewer hose up in no time. The PVC rain gutter will provide a smooth surface for the hose to slide on as it's inserted and removed.
Also, make sure the bumper cap is a good snug fit. They vibrate loose easily and then the hose creeps out while you are moving and if you don't notice it in time, it will hit the pavement and the shredding will begin.
When I'm hooked up, especially for multiple days, I leave both dump valves open. The gray water tank will fill quickly if the valve is closed. Then in the morning before I do anything, I close the gray valve then I take a shower, make breakfast, wash dishes, etc. Just before I unhook I open the gray valve to flush the lines with the freshly accumulated gray water.
Everyone has their own preferred way of doing this but this is what has worked best for me with my Bigfoot and I've never had any problems with the waste water system since I adopted this process. YMMV.
trainjunkie is offline   Reply With Quote
Old 03-03-2016, 09:58 AM   #9
ZachO's Avatar
Montana
Thanks Mike. Definitely good to know. I'll do that.
Old 03-03-2016, 11:16 AM   #10
Rhinoflex is the only sewer hose I know of that is black with orange fittings at the ends.
Old 03-03-2016, 11:58 AM   #11
ZachO's Avatar
Montana
Perfect, thanks Tom.
Old 03-03-2016, 12:39 PM   #12
WaltP's Avatar
Trailer: 2017 Escape 17B
SW Virginia
my 2002 waste outlets were 3" bayonet for the black tank, pointed straight down, and a regular garden hose fitting for the grey tank, in an awkward location.
With the original dropped axle everything was quite close to the ground and very cumbersome to access.
After I raised everything with a straight axle and spring over conversion I had enough room to replace both waste lines and connect them to a common 3" bayonet outlet like a modern system. I had done the same conversion to both of my old Casitas and knew I couldn't settle for less. The improvement in convenience and time at the dump stations is wonderful.
Walt
Old 03-03-2016, 01:03 PM   #13
ZachO's Avatar
Montana
Ok thanks Walt. When I get back home I'll look under there and see what I've got.
Old 03-03-2016, 03:10 PM   #14
Your hot water tank has a bypass & drain, there is also a drain under the fresh water tank hard to see standing. It would be a good idea to put a little bleach in the water holding tank then fill with water to clean it out. Your water pump is located under the bench next to the closet. Make sure you have a pressure reducer between the water inlet and trailer.
bigfoot
Belly bands and city water and the water drain plugs Cheyanna83 Problem Solving | Owners Helping Owners 0 05-25-2015 07:24 PM
Escape Trailer Sewer Hose Holder Thane Modifications, Alterations and Updates 13 06-10-2013 07:04 PM
Sewer Hose Holder JIM KRAMME Modifications, Alterations and Updates 5 04-10-2006 09:12 AM
Sewer Hose Question Legacy Posts Problem Solving | Owners Helping Owners 1 12-16-2002 01:31 PM
How not to connect a sewer hose Legacy Posts Jokes, Stories & Tall Tales 8 12-13-2002 06:04 AM
