Black/grey water tank leak? - Fiberglass RV
Old 08-02-2014, 09:34 AM   #1
frank_a's Avatar
Trailer: 2012 ParkLiner #006
Boy, I have had more problems with this trailer since getting it back from the factory a couple weeks ago. This morning I was laying on my back and trying to do some work under the port side of the trailer and felt something wet on the back of my head. Son of a gun, I have a leak from the black/grey water tank. This is a 2012 trailer! Sheesh!
Does it look like there's a crack there to the right of the drip (obviously the pic is upside down)? What would cause this and how would I fix it? Is it something I should bring to an RV shop? I know nothing about these waste systems, but guess I'm about to learn!
2012 ParkLiner #006
2013 4wd Escape 2L Ecoboost with 3500# tow package
Old 08-02-2014, 09:49 AM   #2
TomK's Avatar
Frank, it looks like there is moisture coming from the top of that fitting and dribbling own to the low point at the tank. Do you see the beads of water on the right side as you look at the picture? See if you can feel any moisture nearer the top. You should be able to feel if that line you pointed out is a crack with your fingernail. Maybe just needs to be resealed at that fitting, as opposed to buying something.
Tom
Old 08-03-2014, 01:58 PM   #3
frank_a's Avatar
It's leaking around this seam, mostly to the right where Tom noted the moisture. When I gently move the pipe, it leaks more.
Any suggestions?
2012 ParkLiner #006
Old 08-03-2014, 03:55 PM   #4
Borrego Dave's Avatar
Trailer: Casita SD17 2006
Frank they do make a two part repair kit. I've used it a few times with good luck.
Old 08-03-2014, 04:12 PM   #5
frank_a's Avatar
Boy, great news Dave. I'll see if I can find one. Thanks!
Frank
2012 ParkLiner #006
Old 08-25-2014, 11:02 AM   #6
Virginia
Grey water tank leak
Dave, I just bought a 2014 Scamp and I am having the same problem as Frank. Could you please tell me the name of the repair kit and where I can find it? Thank you.
Happy Scamper is offline   Reply With Quote
Old 08-25-2014, 11:10 AM   #7
frank_a's Avatar
I'm not Dave, but I bought a two part epoxy in a tube, the kind that is just cylindrical, grey outside, black inside. You squeezed a bit off and mashed it around between your fingers until the two parts where mixed, then put a bead of it around a clean dry seam. So far it works.
Frank
2012 ParkLiner #006
Old 08-25-2014, 02:43 PM   #8
I really don't remember the name of it. Most RV supply stores carry it. The last time I bought some it was in the plumbing section hanging from a rack in a carded package. Seems like it was around 10 bucks.
Old 08-25-2014, 03:20 PM   #9
Virginia
Grey Tank Leak
Frank
Thank you Frank. We have used this type of two part epoxy we bought at Home Depot to fix other things, but I was not sure if it would damage the tank. My husband had thought about using it to fix the leak, but I was wondering if that would be anything especially recommended for that. Thanks for the reassurance. We are going to use it before we go camping again after Labor Day.
Old 08-25-2014, 03:29 PM   #10
Virginia
Thank you Dave. As I mentioned to Frank, we used this type of epoxy for fixing a lot of things. We got it from Home Depot but I believe it is probably the same. I just needed reassurance that the tank was not going to melt, since Scamp has all these warnings against using chemicals that might damage fiberglass. Perhaps the grey tank is not made of fiberglass. We are going to try it.
Old 08-25-2014, 03:41 PM   #11
Hi Vee, your tank is not FG. Not sure what it is from HD but the different tanks on RV's are made from different materials and the repair kits are designed for use on specific tanks. I'll do a little digging and PM you.
Old 08-25-2014, 05:45 PM   #12
Name: lee and katie
Trailer: Parkliner
Florida and Virginia
My waste tank had a leak at the same place when I brought it home. Aaron and Tom suggested using ABS glue to seal it. According to Aaron the glue softens the ABS tank and line and welds it together. It looked like not enough glue was used when the drain was assembled. I found there were three "viscosities" of the glue. I used the thickest level and used the camper last week with no problems.
I discovered another leak when testing the first repair. The tank manufacture apparently marks the center of the 2 flange areas on the tank with a scratch awl or something sharp. Someone was a bit to enthusiastic and the unused rear flat area had a hole into the tank. I doped the hole with the same glue and installed a 3/4" ss screw and fender washer with a neoprene gasket and then covered all of it with glue. When dry I covered it with some epdm roof repair tape...overkill!! No leaks!
My trailer leans to starboard(curb, kitchen). The frame is ~3/4" lower on this side(measured on a level concrete floor) at the rear of the axle. It causes my AC to leak on to the floor if I don't level or over level it. No biggy... I'll try the AC repair posted here by Brian when I have time and be certain it is level each time. Does anyone know if the axles are adjustable?
We used the camper for the first time since delivery last week by going to VA's Grayson Highlands state park. Beautiful!! "Wild Ponies" mobbed us on a hike looking for handouts.
The Parkliner is not as roomy as our 5th wheel but we managed well. Much easier to tow and park than the 5th wheel!! And breaking camp in a thunderstorm was much easier than the big one.
All three campers that we owned have had problems of some sort. Small inconveniences to major damage. Part of having a house on wheels... look at the Airstream forum to see even the "Cadillac" of trailers have problems with leaks, corrosion, rivets etc.
Sorry, I diverged from the topic but I have not posted since delivery.
We love our Parkliner.
Get out there and camp.
Lee and Katie
wandererlee is offline   Reply With Quote
Old 08-25-2014, 06:57 PM   #13
Virginia
Thanks Dave. You make a good point that repair kits may not be suitable for different tanks. I need to call Scamp and ask them what they are made of. Thanks for offering to research it for me.
Old 08-25-2014, 07:11 PM   #14
Virginia
Grey tank Leak
Lee and Katie
Thanks Lee and Katie. I guess I am not alone. It is very disappointing when you bring a brand new trailer camping for the first time and it leaks. I thought it is not supposed to happen. It sounds like this ABS glue is only recommended for ABS tanks since it actually melts the tank to fuse it. I need to find out what my tank is made of.
Plumbing black/grey water Steve Hammel Plumbing | Systems and Fixtures 19 10-07-2012 05:27 PM
black/grey/fresh water tanks Saskstu Problem Solving | Owners Helping Owners 10 07-14-2012 08:11 AM
Grey or Black Water Tank on 13' Trailer? sj2moncton Plumbing | Systems and Fixtures 4 09-14-2010 05:14 AM
Black water-Grey Water ROIDON L Plumbing | Systems and Fixtures 3 07-23-2009 06:09 PM
