Black Water Tank - Fiberglass RV
Old 04-23-2012, 02:00 AM   #1
Black Water Tank
I have an Escape trailer and I would like to really clean the tank. The sensor also does no work in that tank. I have seen adverts at campgrounds for people who do this work. Does anyone know what they do, how they fix the sensor?
Greg Conly is offline   Reply With Quote
Old 04-23-2012, 06:49 AM   #2
In general, tank level systems don't age well and it may be more than a tank sensor problem. However, often the tank level systems stop working because the sensors are all crudded over and can't conduct. The way I keep my tank clean is every few months, before starting out on a trip, I drain and rise out the tank with hot water and then put in about a 4 oz of laundry detergent and several bags of ice cubes wih a few gallons of water. By the time I drive and hour or two the ice knocks everything loose and it flushes out when I get to my next stop with a dump. It's worth a try.
Old 04-23-2012, 08:04 AM   #3
As Bob indicated the sensor in blank tanks not working correctly is common - could be something as simple as a piece of TP blocking it.
After dumping the black water tank, using a wand down into the tank from inside the trailer often helps to avoid the problem but Bob's suggestion of dumping a couple of bags of ice cubes into the tank & driving around with it does the job even better! If it is indeed a simple matter of the sensor being dirty that should fix it & you will have a real clean tank as well.
Old 04-23-2012, 08:20 AM   #4
Kevin K's Avatar
Trailer: 17' Casita
Mpls,Minnesota
Add some calgon water softener powder also (1 cup to the tank with gal water)
Ice cubes
Laundry detergent powder or liquid
Calgon water softener powder
1 gal water
Old 04-23-2012, 09:31 AM   #5
Thanks, I will try them all.
Old 04-26-2012, 05:43 PM   #6
Trailer: Escape 5.0 (sold) :(
Greg,
Escape sells a modified wand cleaner. It has two sets of holes, one set angled to clean the black tank sensors and one for the gray sensors. I have used it to clean my gray sensors and it worked perfectly. If you can't buy one from Escape, you probably could modify one yourself. You would have visualize what angle the nozzle needs to be considering the location of the sensors and location of the wand. If you have questions, let me know.
The ultimate solution is to install a tank rinser. I put one on my black tank and it is terrific. No effort, just connect a (dedicated) hose to the external water inlet and let it go for a couple minutes.
Marv
Marv is offline   Reply With Quote
Old 04-30-2012, 09:36 PM   #7
Here are the pics of the rinser. The first view is inside the left forward cargo bay on the Escape 5.0, showing the rinser installed in the black tank. The second view shows the water inlet mounted on the outside of the trailer.
Old 05-01-2012, 11:00 AM   #8
Trailer: 16' Scamp
Have there been any posts or other sources of information about building a custom tank out of fiberglass and epoxy? I have been wishing for more blackwater capacity in my 16' Scamp, 9.5 gal only lasts a few days. It seems to me that the tank could be both wider and taller without sacrificing a thing. It's bound to be cheaper than a new tank too, not counting time of course. . .
bouwsmaj is offline   Reply With Quote
Old 05-01-2012, 11:43 AM   #9
John if you have not already considered it a 12 gallon tote is one simple and fairly cheap option. I have used mine when dry camping to drain off the grey and black water when the tanks get to full.
Old 05-01-2012, 02:55 PM   #10
John,
Check out West System (here). They have a ton of info about repairing and building using glass and epoxy. Browse their Epoxyworks online magazine at the same website. Also consider sourcing a tank from one of the trailer manufacturers. Many sizes to choose from, although price and shipping might be an issue.
Old 05-01-2012, 03:21 PM   #11
Hi John, welcome to FiberglassRV... we're glad you found us.
I'm with Carol on this one. While you could make the tank a bit larger... not, that much larger. At least not as large as a tote. In fact, we've had members complain about the seat being too high on some of the toilets and their legs dangle (sorry if this is TMI). A tote can be used also for the gray water... so that makes it win/win.
Old 05-02-2012, 08:08 AM   #12
Trailer: 16' Scamp
Thanks to all of you. The tote idea is certainly the most practical. My first instinct is always to build things myself, but it's not always the best plan. I will investigate the Epoxyworks archives, and ponder the effort involved.
John
Old 05-02-2012, 07:01 PM   #13
Well John, how about making your own Blue Tote?
PS: I used a Dremel tool to cut the threads in the neck of the container.
Some of the model numbers may have changed.....
Old 05-03-2012, 06:26 PM   #14
Trailer: 16' Scamp
Donna D,
That's brilliant! I may very well do exactly that. Your instructions are also excellent, and I am speaking as a former professional writer of assembly instructions.
John
Black water tank DaveK Care and Feeding of Molded Fiberglass Trailers 21 03-24-2012 10:51 PM
So, Where's Your Black Water Tank Located? Cathy P. Care and Feeding of Molded Fiberglass Trailers 27 02-19-2012 08:48 AM
17" Boler Trailer - Waste Water - Black Water Tank waroibns Plumbing | Systems and Fixtures 6 05-20-2011 08:19 AM
Calgon etc. in the black water tank??? Alf S. General Chat 13 05-15-2008 04:45 PM
17' Boler Black Water Tank Dwight Burditt Problem Solving | Owners Helping Owners 6 04-18-2008 09:16 PM
