Black Water Tank Removal - Fiberglass RV
Old 08-09-2013, 06:26 PM   #1
Trailer: Bigfoot
I have a 2000 19' Bigfoot travel trailer. I'm trying to remove the black water tank due to a leak. I have it completely uncovered and unstrapped, but am having trouble with the toilet-to-tank connection. Can anyone offer suggestions as to how to proceed?
Thanks,
Ray
Ray1919 is offline   Reply With Quote
Old 08-09-2013, 08:43 PM   #2
Brian B-P's Avatar
I don't know about the Bigfoot 19' specifically, but usually RV toilets use mounting flanges just like a home toilet, so if you can find them there are likely two nuts at the base to remove to free the toilet from the tank-mounted flange.
Old 08-09-2013, 08:51 PM   #3
Brian is correct... my Scamp is a "marine" toilet. ALL parts other than the discharge are inside the body of the trailer. A couple of bolts remove the china toilet from the black water tank (which it sits on, inside the body).
Is it different in yours? Pictures
Old 08-10-2013, 02:40 PM   #4
Trailer: Bigfoot
I have already removed the toilet. It's the drain pipe between the toilet and the black water tank that is causing the problem. I can't see how to either remove it or release the tank without removing it.
Black Water Tank Removal on 5th Wheel Scamp Steve Hung Plumbing | Systems and Fixtures 5 08-20-2010 07:35 PM
Black Tank Removal 94'Casita SD 16' Joe Z Modifications, Alterations and Updates 8 05-18-2007 07:37 AM
Toilet black tank removal on casita Joe Z Plumbing | Systems and Fixtures 15 05-13-2007 02:31 PM
Black Tank Removal 94'Casita SD 16' Problem Solving | Owners Helping Owners 0 01-01-1970 12:00 AM
Toilet black tank removal on casita General Chat 0 01-01-1970 12:00 AM
