The pump in my B1700 on the floor, the tank is underneath, and the maximum height the pump needs to draw is about 20 cm (8") - which has not been a problem at all for our pump, which looks original to the 1979 trailer.
Like Benny, I can understand that there may be reasons to put the pump under the floor, but I would rather have it clean and dry inside, even with the noise. Someday, I may even understand why it was mounted under the gaucho, instead of the obvious location under the sink...
