Boler pipe and fittings under sink - Fiberglass RV
Old 06-01-2015, 04:08 PM   #1
Nova Scotia
Hello all
We noticed a pipe under the sink was split. It's from the campground water inlet to the tap. A local RV shop said they wouldn't have the fittings. We are assuming we will replace it with a pex pipe and fittings - is that what is recommended and does anyone know what fitting is used or a good place to look for them? We have found a shop called hose and fittings in the area so we will probably visit them tomorrow. Eventually, we will probably put a new receptacle/sink/faucet in but we just want to get it up and running for a season to get some use out of it. I think both fittings are female
Thanks!
Jeannette in NS is offline   Reply With Quote
Old 06-01-2015, 04:13 PM   #2
That shouldn't be a big deal, just make sure what you use is for drinkable water.
You may be able to even use the white drinkable waterhose and fittings and clamps, Cut the hose to length.
Here in the US we can get clear hose at Lowes, by the foot, along with fittings and clamps. PEX pipe and fittings there also.
boler
Broken Sink Pipe Wallo Problem Solving | Owners Helping Owners 2 07-21-2013 09:20 AM
Plumbing fittings? Jake Jacobson Plumbing | Systems and Fixtures 13 10-26-2008 04:13 PM
Where to Buy? New propane lines, fittings, etc? Kurt in BC Problem Solving | Owners Helping Owners 9 06-12-2008 05:27 PM
Gray water fittings and connections? Roy in TO Plumbing | Systems and Fixtures 4 06-02-2008 11:52 PM
Exterior Fittings DanPatWork Problem Solving | Owners Helping Owners 2 01-09-2008 07:49 AM
