Braided vinyl tubing - Fiberglass RV
Old 06-04-2015, 10:37 PM   #1
Hey, anyone use braided vinyl tubing for re-plumbing? It has a high psi rating, easy to bend and no special tools needed to attach as well as no weird taste. Pros /cons?
James Mc is offline   Reply With Quote
Old 06-05-2015, 05:31 AM   #2
Trailer: Scamp Deluxe 16
We had braided vinyl under our kitchen sink in a 13' Scamp. It was a short amount of tubing (from the sink to the drain outlet). I wrote 'had' because the camper was sold.
Sheryl M is offline   Reply With Quote
Old 06-05-2015, 06:37 AM   #3
It is OK as long as it is protected from the sun and is located where you can see it.
Sometimes it separated along the fiber reinforcement and is more of a tube within a tube.
The pressures you will have in a trailer with a pressure regulator to protect from high city water pressures will be well within the ratings and should work OK.
Hot water would not be as good of an idea, however.
On my rebuild I am planning on using PEX, but as you know it is considerable more difficult to work. I may change my mind and use the vinyl as well.
Old 06-05-2015, 06:41 AM   #4
possible con...
all the braided nylon tubing I have come across is very stiff.....while it may take a huge amount of psi, it may be too stiff to make a psoitive seal around a barbed fitting...especially in smaller diameters typical with our applications
bigger/stonger is not ALWAYS better.....in my trailer there is a PRV that limits pressure to 25-30 psi...garden hose can handle that...and then some
Old 06-05-2015, 06:45 AM   #5
mmeyer's Avatar
Trailer: U-Haul VT
Indiana
I used pex and shark bite fittings when I re plumbed my UHaul VT pressure side and the braided vinyl drain side. Worked out fairly well, with a few issues on the drain that were solved by heating with hot water to make it pliable.
mmeyer is offline   Reply With Quote
Old 06-05-2015, 11:20 AM   #6
Well, it's not going to have a hot water tank, and honestly I can't see myself ever hooking up to city water, the last trailer I owned for 4 years and not once did I hook up to a city water line. I have a shurflo pump waiting for me to get it installed and just needed to know what would work for that. The old hand pump system used clear vinyl tubing, but I realise there is ultimately no pressure in that line, so the unbraided tubing makes sense. I just don't want to over-complicate my plumbing setup for no reason
Old 06-05-2015, 01:05 PM   #7
frank_a's Avatar
Trailer: 2012 ParkLiner #006
I have a current problem like this, with 1/2" pex attaching to that vinyl reinforced hose with about a 5/8" outside diameter. Do you have a sharkbite fitting number I could use on that by any chance?
Thanks!
Frank
2012 ParkLiner #006
2013 4wd Escape 2L Ecoboost with 3500# tow package
Old 06-05-2015, 02:44 PM   #8
I put a pressure limiting device on the input water hose connector when at a campground. You can get on at WalMart. There are 2 types, the least expensive will limit to 50psi and a more expensive one is adjustable. I doubt if your on board water pump would exceed 50psi.
Old 06-05-2015, 04:46 PM   #9
2 years ago when I replumbed my Scamp 13 I used all new clear polyurethane braided hose. I like the stuff its all routed inside the trailer. Bends to tight radius without constricting and no special fittings. At any time I can see if anything is funky inside my water lines.
In SO CAL I don't have issues with freeze thaw but I do have relatively warm water sitting in the lines for months on end. Its good to be able to actually see whats inside my lines.
Old 06-05-2015, 07:13 PM   #10
Dennis mn's Avatar
The first thing I did when I bought the Scamp was to redo the strange pluming installed by the original owner. The water heater supplied heat for the shower only. I made a serious mistake of not looking at the temperature/pressure rating of the tubing. First time I went camping, I looked under the sink, the tubing looked like a balloon just before it broke! I replaced the tubing with tubing of proper temp/pressure rating. Eleven years on, and there have been no issues. I do carry a roll of this tubing under the sink.
1999 Scamp Fifth Wheel, pulled by a 2014 Nissan Frontier Pro4-X
Dennis mn is online now   Reply With Quote
Old 06-05-2015, 08:42 PM   #11
I just finished putting a bunch of this in my 17' boler. Found it fairly easy to work with compared to the Pex. I used a lot of hose clamps to make sure it didn't leak or pop off the fittings. Time will tell I guess. I found it kind of inbetween as far as price goes because the shark fittings are really expensive. Plus not impossible, but more difficult to get off if I need to reconnect or make changes. I put the foam insulation around the line from my hot water tank to the shower to make it a little more efficient too. Hopefully if I don't get all the water out this winter too it will be strong enough to take a bit of freezing.
TimR is offline   Reply With Quote
Old 06-06-2015, 07:10 AM   #12
Trailer: Casita 17 ft DLX SD
After 40 years in the trades ,the only place iI saw braided vinyl tubing used was for non pressure applications and never concealed in any structure.
There is a reason they use Pex tubing . Easier to use /install is not always the road to follow
Old 06-06-2015, 07:42 AM   #13
just could be....
that we see braiding and think it equals strength, as in pressure resistant (good thing)....when in fact it equals strength, as in resistance to crushing/kinking....I've seen a lot of braided in boats where lines have to run in tight quarters with a lot of sharp twists and turns...and most of those were non-pressure applications
they'll work fine in pressure applications, I guess, if you have the room to route them...and you can get a good/reliable seal (a tall order IME)
Old 06-08-2015, 01:01 PM   #14
I used a short section of clear braided hose under my sink when I added a pressure accumulator, haven't had any problems. Main thing is you can't run hot water through it. But the type of hose is common, and easily attaches with 1/2" barb fittings and hose clamps. Forgot to add that it was more flexible than pex which is why I used it.
ThomasE is offline   Reply With Quote
vin
foam backed vinyl Harry Young General Chat 2 08-09-2015 09:04 PM
Green and white tubing summer scamp Problem Solving | Owners Helping Owners 2 04-23-2014 08:05 PM
Multi Purpose Bilge Tubing D Davis Problem Solving | Owners Helping Owners 0 04-13-2012 06:04 PM
Need assistance to replace vinyl covering tanya quinn Problem Solving | Owners Helping Owners 1 06-09-2009 10:12 PM
Protect your propane tubing Victor Benz Problem Solving | Owners Helping Owners 3 05-26-2006 11:29 PM
