cassette toilet fix - Page 3 - Fiberglass RV
Old 04-12-2015, 08:29 PM   #29
Gilles's Avatar
Trailer: Bigfoot 15B17G, 1986.
Quebec
Originally Posted by LeaAnn View Post
WOW! I did not know that.....I am going to try that now, maybe it is not too late. Maybe I can save it for a back up one day....
Leaann
Give us the result, if it's o.k. or not...
Gilles
Bigfoot 15B17G.
Towed with Dodge Journey 2012, 3.6 L., 6 speeds.
Old 04-13-2015, 11:07 AM   #30
Trailer: currently shopping
Has anyone notified Lil Snoozy of the common problem with cassette toilets? I am considering buying a new one but don't want to fool with issues right away.
Missouri Mark is offline   Reply With Quote
Old 04-13-2015, 12:05 PM   #31
Trailer: Lil Snoozy
Well, I guess my phone had been wet way too long. Today is another day, and it still does not work, So goes the hope of a back up... (I will try again if needed in the future.) I will not forget the advise if another phone decides to go swimming.
LeaAnn
LeaAnn is offline   Reply With Quote
Old 04-13-2015, 12:09 PM   #32
Trailer: Lil Snoozy
I do believe that Thetford has been notified. I know I have personally sent an email. it was also mentioned on the LilSnoozy forum. Not everyone has had a problem. We have not until now. We have had our cassette toilet for over 3 years and no problems. Just one of those things that goes along with the adventure of campers/rvs.
LeaAnn
Old 04-13-2015, 01:06 PM   #33
BAMA & Pachyderm Posse's Avatar
Arkansas
so meany times I cant count if you have a cassette toilet like the ones in the snoozys you will replace the blue hose sooner or later . I can grantee that !
HERSCHEL AKA BAMA
BAMA & Pachyderm Posse is offline   Reply With Quote
Old 04-13-2015, 03:25 PM   #34
Trailer: Escape 21 Nov.2016
Lil Snoozy
Lil snoozy is aware as is Thetford that makes the cassette toilet .It's a catch 22 Lil snoozy cannot put a different tube in instead of the crappy blue one way to thin and prone to rupture . Other wise cassette toilet is not warranteed . So go witha porta potti and be happy or buy cassette and wait for the blue hose to rupure then fix it .I tusually lasts about a year or so . Jim
jennykatz is offline   Reply With Quote
Old 04-13-2015, 08:13 PM   #35
Gilles's Avatar
Quebec
LeaAnn
That makes only 24 hrs. Continue until 48 hrs if it is not later completed 24 hrs.
Gilles
Bigfoot 15B17G.
Old 04-14-2015, 08:17 AM   #36
This news makes me a little leery of Lil Snoozy. The cassette toilet was a feature that has me leaning toward the Lil Snoozy. I thought what a neat concept. Vs. a porta potty, I would much rather have a hatch outside the trailer to pull out and dump, rather than carrying it thru the inside of the trailer, plus I would think the smell on a porta potty would be an issue. The cassette was a big selling point for me versus the black tank. Seemed so simple. But it scares me that a manufacturer would put something in a $20,000 plus trailer that is known to falter within a year or so time. It makes me wonder about the integrity of the entire unit.
Some of you say it is just a matter of changing out a blue hose to another sturdier one, but nothing is ever that simple for me.
Old 04-15-2015, 06:19 AM   #37
cassette toilet
The problem with the blue hose is the design of the cassette toilet you can move it to make more room in the toilet area to take a shower because it's a wet bath . plus the fitting are not the s/s screw type they are a squeeze fitting .
If you are considering the snoozy has many fine attributes
1-Rear door entry easier to load bikes and things
2-6ft 4in headroom
3-A/C 8000 BTU easily replaced under $150 instead of roof A/C $900
4-full 8ft width for better stability while towing plus if you get a flat it will not break into fiberglass or wood flooring .
5-Full Fiberglass floor no OSB flooring like scamp and parkliner ?
6-they will pre propane for you so you can get propane if wanted also will put in 12 volt fridge for extra$
7- Cassette toilet (5 gal) no BLACK tank easy to dump at home or restroom
We have the twin bed model the only complaint has been the cassette toilet which I fixed . no closet which I ran a hanging bar between the two beds for clothing .It tows really nice
Old 04-15-2015, 07:35 AM   #38
charlsara's Avatar
Trailer: 2014 Lil Snoozy
Our LS is 9 months old. I was looking at the toilet last night. The hose replacement looks fairly simple. I will change mine after I finish my side dinette.
From reading here and on other forums, I have seen problems with all brands of trailers. I guess the Thetford hose is ours. I do think it is worth the effort.
Old 04-15-2015, 11:06 AM   #39
I will keep an open mind and Lil Snoozy is still at top of my list, with Egg Camper a close second. If either are ever interested in selling your Snoozy, let me know.
Old 04-25-2015, 10:27 PM   #40
MCDenny's Avatar
Trailer: Lil Snoozy
There are two separate blue hoses. The first one which connects the Pex that Snoozy supplies to the flush valve. That's easy to fix without taking anything apart. I added a shut off valve which gives a way to isolate the toilet from the pressure water system plus a way to adjust the flushing pressure. Thetford supplies a small disc with a tiny hole that slows the water flow. Unrestricted it will spray all over the bathroom.
The second blue hose failed a year later. This one is a pain as you have to take the toilet out to get access to the hose. Jim gives the directions above.
I don't know of a cassette toilet option besides Thetford. I found lots or reports on other trailer forums of the "blue hose" problem.
Denny Wolfe
Wanderingourway.wordpress.com
MCDenny is offline   Reply With Quote
Old 04-27-2015, 08:23 AM   #41
Still think it sucks that a company would put a product out knowing dang good and well that there is a specific problem and it will probably fail in a year's time. I fault Thetford for putting the product on the market and Lil Snoozy for using it, especially if Lil Snoozy owners do not tell buyers of the potential problem.
Old 04-27-2015, 08:51 AM   #42
Arkansas
That is one of the reasons I started the lil Snoozy Owners club . every time they change the manger gets worse when it was Nicklaus and his Dad it was at the best it has been , but that said, I sold mine way to meany problems with the snooz it was a LOVE HATE thing it had to go . welcome to snoozy world
HERSCHEL AKA BAMA
Storing Toilet Paper Roll in Toilet-Shower Combo S Sato Plumbing | Systems and Fixtures 24 04-18-2015 12:46 PM
1981 Trillium holding tank/toilet fix Lee Senn Plumbing | Systems and Fixtures 3 06-03-2012 06:51 AM
3rd Annual Spiff-n-Fix! August 21, 22 and 23, 2009 Gina D. Rallies, Get-togethers, Molded Meets (Archive) 47 09-19-2009 10:02 PM
Fridge not working... Is it worth trying to fix it? Rob Carmody Problem Solving | Owners Helping Owners 6 09-06-2008 03:08 PM
Replace old toilet or go portable toilet Paddy Morris Plumbing | Systems and Fixtures 7 04-25-2006 06:17 PM
