Cleaning water tank - Page 2 - Fiberglass RV
Old 02-24-2014, 07:46 PM   #21
Originally Posted by Filbert V. View Post
That's it then, I'm filling it up with tequila and stocking up on limes to prevent scurvy while I'm at it. A bit of salt, and at least I'll waste away with a smile on my face!
As some know that would be my highly recommend approach to the issue!
Old 02-24-2014, 07:49 PM   #22
Francesca Knowles's Avatar
Trailer: '78 Trillium 4500
That's the "spirit"!
Just make sure you get that tequila with the worm in it- that Bad Boy'll scare off any/all other such critters. Works best if using the "worm still alive" version of the tequila, of course.
Old 02-24-2014, 08:14 PM   #23
Filbert V.'s Avatar
Trailer: Tote N Tarry
Let me know next time you're passing through San Diego Francesca and I'll whip up a batch of my famous margaritas for you. We're only 15 minutes north of Mexico you know
Filbert V. is offline   Reply With Quote
Old 02-24-2014, 10:22 PM   #24
It's a date, Sistah! But...San Diego- California? That's a fur piece from my reglar stompin' grounds.
Thing is, my parole officer set my ankle bracelet to "Autokill if going across the Southern Oregon Border". And the only reason Oregon lets me in is because I was born there and it continues to believe it bears a certain responsibility for the outcome of that event.
I heard that the California Inspection Stations are on a permanent lookout for a whole list of contraband items; which list includes firewood, vegetables, and me. But I haven't attempted to cross since the Schwartzenegger Administration there, which I understand has since been replaced with another, perhaps more...shall we say "Francesca Friendly" one?
Girding my loins for another attempt...if there are enough air holes in the trunk you'll be hearing from me!
Old 02-25-2014, 05:57 PM   #25
Brings back memories of my college days. We had the electric water cooler filled with vin rose. It was handy, and didn't require sanitation measures!
Russ
Old 02-26-2014, 07:23 AM   #26
Filbert V.'s Avatar
Ah yes, I graduated from SDSU 30 years ago. Good ole college days.
Old 02-26-2014, 12:10 PM   #27
Go Aztecs!
Old 02-26-2014, 12:44 PM   #28
David Tilston's Avatar
A tidbit that I picked up from watching TV.
If you don't have access to clean drinking water. Fill a clear, 1 liter pop, or water bottle with the clearest water you can find, then lay it out in the sun for a day. The UV kills the bugs in the water. After a day it is safe to drink. This does not work for cloudy water.
Old 02-26-2014, 12:58 PM   #29
The problem with that solution is that even bottled water has a "best before date" and that's because it contains bacteria that multiply over time.
Perhaps, leaving bottled tap water out in the sun might work, but is also likely to warm the water, improving the environment for bacteria.
Wasn't Dr. Oz was it??
Old 02-26-2014, 01:16 PM   #30
Nope, PBS. As a solution for third world water borne diseases.
Old 02-26-2014, 01:58 PM   #31
Looks like David's spot on: Clean Drinking Water for Everyone | Michigan Tech News.
Requires continuous exposure to strong sunlight for six hours. Also needs reasonably clear water- bacteria will hide from the radiation under sediment. U.V. radiation rather than temp is the sanitizing factor- kills those bad boys dead as a doornail!
Thanks for the tip, David!
Old 02-26-2014, 02:34 PM   #32
There was a far bit of chatter in the international travel forums a number of years back on the topic of solar water disinfection. One of the reason when I travel in counties that are not known for great water, when I buy bottled water (which is often bottled in the country of purchase) I leave it out in the sun for a day before sticking it in the fridge to cool down.
Wikipedia, has a pretty good explanation and history of Solar water disinfection.
Old 02-26-2014, 09:23 PM   #33
Trailer: 2012 Escape 19
I graduated from SDSU 25 years ago! Go Aztecs!
2012 Escape 19
New to us in May 2014
JaneM. is offline   Reply With Quote
Cleaning out water tank? barryra Care and Feeding of Molded Fiberglass Trailers 44 03-25-2015 10:55 AM
New water tank and exterior tank fill "door" Treedles Modifications, Alterations and Updates 10 10-11-2013 10:38 AM
Water tank cleaning? Filbert V. Care and Feeding of Molded Fiberglass Trailers 20 09-04-2012 05:02 PM
Trouble adding water to a fresh water tank Dan Tracy Problem Solving | Owners Helping Owners 1 05-05-2008 08:11 PM
