Convert Gray Water Pipe from 1 1/2" to 3" - Fiberglass RV
Old 08-11-2011, 10:53 AM   #1
Hello,
Our 13' Boler's gray water drain is a 1 1/2" PVC pipe. Right now we use a bucket to collect the water and dump it in the sewer when full, but I would prefer to have a more standard system, and it looks like all standard sewer hoses are 3" wide or larger. Any simple plumbing attachments out there to convert a 1 1/2" pipe (with threads on the inside) to a 3" pipe? Or any 1 1/2" sewer hoses available anywhere? Many thanks!
Chantal
Chantal L. is offline   Reply With Quote
Old 08-11-2011, 12:44 PM   #2
Joe MacDonald's Avatar
there are several types of adapters, you can go from 1-1/2 to 3/4 inch garden hose, or from 1-1/2 to 3 inch, then add a gate valve.
google: rv waste valves, and abs adapters.
Joe
Old 08-11-2011, 01:54 PM   #3
KevinWA's Avatar
Trailer: Trillium 4500 1978
a brand called "ferco" makessome nice MJ bands...easy one step change from 1.5 to 3 inch.
KevinWA is offline   Reply With Quote
Old 08-11-2011, 04:58 PM   #4
Joe
Thanks a lot Joe. Will investigate the options. I never thought of going from a 1-1/2" to a 3/4" garden hose. That is probably the route I will take.
Chantal
Old 08-11-2011, 04:59 PM   #5
Thank you very much. Will look at that option as well.
Chantal
Old 08-11-2011, 05:01 PM   #6
Trailer: Fiber Stream
The only reason for 3" is to dump Black water, not Gray... There is an adapter to connect smaller hoses for gray water to an RV campground sewer fitting.
Amazon.com: Camco 39111 RV Easy Slip Grey Water Drain Adapter: Automotive
Then get an adapter for the outlet on the trailer to connect to a garden hose.
Old 08-11-2011, 05:22 PM   #7
The things you learn!... Thank you very much Frederick!
17" Boler Trailer - Waste Water - Black Water Tank waroibns Plumbing | Systems and Fixtures 6 05-20-2011 08:19 AM
"Grunting" water pump BOBSMITH Problem Solving | Owners Helping Owners 1 09-05-2009 03:50 PM
Looking for a 1/2" PVC snap in pipe holder Kevin K Problem Solving | Owners Helping Owners 3 08-19-2009 09:10 AM
