Exposed unsealed floor beams - Fiberglass RV
Old 06-18-2016, 12:44 PM   #1
Ohio
New Scamp and underneath there are metal support beams. They are open not sealed in the direction of the TV. The issue I would see is water,salt,dirt is going right in the holes from back of car as you pull camper. Has anyone sealed these and how would you do it?
Thanks
Scott
Sent from my A0001 using Fiberglass RV mobile app
sal6342 is offline   Reply With Quote
Old 06-18-2016, 12:52 PM   #2
I see you are talking about frame members, it is likely that they will do better left alone but either way they are not a cause for concern.
Old 06-18-2016, 12:57 PM   #3
Ohio
Exposed Beams
Thanks. Floyd for the reply on the beams!
Scott
Old 06-18-2016, 08:17 PM   #4
Dan Meyer's Avatar
Don't worry about it.
If you are worried about it, rinse them out once or twice per year with a garden hose.
Either way, the trailer is going to last 25 - 30 years or even longer.
--Dan Meyer
Old 06-18-2016, 08:50 PM   #5
You might want to spray some rustproofer in them, just for the heck of it.
Old 06-19-2016, 09:18 AM   #6
Trailer: T@B
Arkansas
Trying to seal them might trap moisture, which could be a greater threat to rust. As others have said, I think they will be OK left as is.
RZRBUG
2013 T@B
Larry G. is offline   Reply With Quote
Old 06-19-2016, 10:23 AM   #7
Kai in Seattle's Avatar
Our rear bumper is open like that, and I wanted the welder at Machinists, Inc (where the frame was repaired and painted) to seal it up, but he said it would be far better left open so it could dry out completely between getting wet, rather than potentially trap moisture.
Seemed to me if he were a great welder, he could prevent it from having any gaps at all, but he said to just leave it. So we left it.
Semper ubi sub ubi.
Old 06-19-2016, 10:38 AM   #8
Name: Bill & Jeanie
Trailer: Building camper in Ram Promaster van
If it were my trailer I think I would make a plug for the ends out of metal or plastic, glue in in place with epoxy or poly adhesive, and most importantly drill several 1/4" holes in the bottom of each plug (or the frame itself) for drainage. If you do leave them open be sure to wash them out regularly as dirt or sand will hold moisture, quickly causing corrosion.
wbullivant is offline   Reply With Quote
Old 06-19-2016, 01:30 PM   #9
You're better off leaving it open, than thinking it's totally sealed. This is what happens when water gets trapped in a frame.
Advice on Allure Floor Install - Raising sub floor Tommy Gun Modifications, Alterations and Updates 4 10-12-2015 12:04 AM
Gelcoating Burro Floor to prolong floor life? not-very-clever Modifications, Alterations and Updates 12 11-23-2013 10:29 AM
Burro Floor Rot laura dawn Problem Solving | Owners Helping Owners 20 12-17-2005 02:38 PM
new floor Dennis F. Problem Solving | Owners Helping Owners 2 11-26-2005 10:57 PM
Dri Dek bathroom floor Legacy Posts Care and Feeding of Molded Fiberglass Trailers 11 10-04-2002 05:47 PM
