Exterior Shower - Fiberglass RV
Old 08-19-2009, 03:43 PM   #1
Trailer: Scamp 16 ft
I have a new to me scamp trailer, very excited. It is a 2002 16ft model. I want to add an exterior shower because the toilet/shower area is a little small for showering.
Has anyone added an aux. shower to there unit? Are there places you can and cannot cut into the scamp to mount the aux shower (requires about a 8" x 12" hole). I was thinking of putting it so it pokes into the cabinet that the water tank is housed in. There seems to be plenty of room for the intrusion, just not sure if I can make a hole there.
What do you think?
Also thank you so much for this wonderful site, I was able to get very well educated before I took the plunge.
Matthew A is offline   Reply With Quote
Old 08-19-2009, 04:03 PM   #2
Jim Bennett's Avatar
Matthew, I would see no problem putting it almost anywhere, though I am not familiar with the Scamp. The back of any cabinet you can easily access for hooking up, or maintenance should work. A hole that small should not compromise the integrity of the shell at all.
2017 Escape 5.0 TA
2009 Escape 19 (previous)
Old 08-19-2009, 04:09 PM   #3
Chester Taje's Avatar
I agree with Jim.
Old 08-19-2009, 06:10 PM   #4
Essentially what you're doing is cutting a hole like you'd do if you were putting in a hatch. You may want to check out peterh's excellent topic on the hatch he put in his Scamp, it should give you some pointers:
Adding a hatch
Old 08-19-2009, 06:25 PM   #5
I agree with Jim.
I wish I could just get my wife to do this.
2017 Escape 5.0 TA
Old 08-19-2009, 10:02 PM   #6
Carl O's Avatar
Trailer: 1990 Scamp 16 ft
Personally, if I were thinking of showering outside of the trailer, I would look at something like this: http://www.zodi.com/web-content/Consumer/z...avelshower.html
My 2 cents.
-Carl
Carl O is offline   Reply With Quote
Old 08-19-2009, 11:28 PM   #7
Carl, those would be nice, but if you already have a hot water heater, the bulk of carrying it would be nice. I bet it is great for tenters though.
2017 Escape 5.0 TA
Old 08-20-2009, 01:16 PM   #8
Thanks for all of the help I think I will go ahead and add my shower, I will let you know how things work out.
Old 08-20-2009, 06:18 PM   #9
Robert Johans's Avatar
Trailer: 1988 Scamp 13 ft and 1982 Perris Pacer 13 ft
I'm in the process of a complete overhaul to my 13' Scamp. Many upgrades, not the least of which is an outdoor shower.
When at most RV parks, it occurred to me that the curbside/entry-side is most "private" side, so I located my shower there, just below my "porch" light. This location is on outside of the vertical cabinet inside, so the plumbing is hidden within the cabinet. I'm customizing the interior of the vertical cabinet so that I can have access to all the plumbing, while adding more efficient storage.
Obviously, the shower required cutting a hole into the shell. No big deal, IF you take MUCH care with your measuring and your cutting. I had no serious problems and the results are great.
Good luck.
Old 08-21-2009, 05:05 AM   #10
John Hussey's Avatar
Trailer: 2000 16 ft Casita Spirit Deluxe
Outside shower, CHEAP:
http://www.amazon.com/gp/product/B001F1ZPO...7HAMDWBCAQRA193
I have the above. Takes about 3 hours for 2.5 gallons and enough for two navy showers. Of course, one has to anticipate it's use since it takes time to heat but it is WAAAY CHEAP!
John Hussey is offline   Reply With Quote
Old 08-21-2009, 11:13 AM   #11
For privacy I have the Outback Porta-Privy, a great shower tent that takes about 30 seconds to set up and just a few seconds longer to put away. Folds up to a 24" circle that is about 2" thick for super easy storage. I figure a much better option then trying to squeeze into my Scamp shower.
http://www.evergreen-outdoors.net/ou...orta_privy.htm
Exterior storage box Legacy Posts Problem Solving | Owners Helping Owners 17 06-18-2011 08:40 AM
Exterior Finishes? Ashley B. Problem Solving | Owners Helping Owners 10 08-18-2010 02:19 PM
Replaced the shared exterior wall in my shower. Sealed up window too. Bryan L. Modifications, Alterations and Updates 17 04-27-2009 12:14 PM
Exterior Care Legacy Posts Care and Feeding of Molded Fiberglass Trailers 9 01-23-2003 02:43 PM
Replaced the shared exterior wall in my shower. Sealed up window too. Matt Rudisill Problem Solving | Owners Helping Owners 0 01-01-1970 12:00 AM
