08-23-2012, 07:12 PM
Trailer: Scamp 16' Deluxe side bath
Filling fresh water tank
Hi folks,
I have a 16' scamp and when camping without water nearby I usually haul a couple 5 gal containers with spouts which I then have to lift and pour into the receiver cup for the fresh water tank. These are hard to hold while waiting for them to fully drain.
Does anyone have a better way of filling the tank other than driving to a water source with a hose. I usually fill my fresh water tank once a day.
Thanks,
Tim
08-23-2012, 08:16 PM
Trailer: none
All I use is a 2 1/2 jug, if no water fill station we fill from nearest spigot, then set up camp. We only use minimal water since if I do fill it up (and water heater) I tend to drain almost half of what I put in before we leave so now I basically only fill to get water heater going then fill as necessary. We are only weekend or three day campers so that might make a difference to
My daugher cracked my old filler by resting spout on it when pouring
08-23-2012, 08:42 PM
I use a long flexible line that can be snaked down into the tank, and attache it to a funnel. You can rapidly fill as the air escapes around the tube and doesn't slow down the filling process.
08-23-2012, 10:18 PM
Trailer: Bigfoot 19 ft
Check out this thread:
http://www.fiberglassrv.com/forums/f...ces-41624.html
This is a thread that I started. But it became really involved and you should find some really good ideas. Our fresh water system is based on the ideas found in this thread, and it works great for us!
Good luck!
'02 Bigfoot 21’ | '07 Chevy Tahoe
08-23-2012, 10:48 PM
I have seen people use various small pumps to pump the water from the portable water jugs into the trailer. Something like this would work.
I tend to use only small 5 gallon jugs for topping up my tanks as well for the reason you state. I fill it up at the last possible spot to do so before heading into the dry camp. When filling I also make sure the pump is on so that the hot water tank fills and I go inside and flush the toilet a couple of times to get some water in the hot water tank to start out with. Wth two people showering I can usually get by for a couple of days without refilling the tanks. Are you also having to drain off your grey tank every other day as well? If not then perhaps the tank isnt actually filling all the way the first time you fill.
08-24-2012, 06:59 AM
Trailer: 2015 Escape
Here's something you could try. We once saw a guy filling the tank on his VW camper with a coffee pot. Probably took a while and got him some exercise walking from the spigot to the camper. Pretty sure lifting the coffee pot didn't do anything bad to his back.
08-24-2012, 08:22 AM
a windshield washer pump is a good way to pump water from a container into holding tank. Their not too expensive and with a bit of wire and tubing you can make up a rig to do the job.
RRJR
08-24-2012, 10:06 AM
RRJR
Good idea. I bought a nice little 12 volt pump on eBay to make an outdoor shower.
08-24-2012, 11:08 AM
You could also use a hand pump used for winterizing with anti freeze. If you are using non toxic RV anti freeze and rinsed it out well after using the anti freeze it should be fine for fresh water use. Would make it a dual purpose small trailer item! ;-)
08-24-2012, 01:53 PM
I'm with Hambone, 2 1/2 gallon jug, about 20 lbs full. I bought two but in most cases only take one with us. If you can enlarge the breather, the flow is smoother. Raz
08-25-2012, 03:27 PM
Originally Posted by Donna D.
Harbor Freight has these, too, and for less $$
08-28-2012, 12:24 AM
Here's what I use. You can use a hard sided container also or any water container for that matter.
Joy A. & Olive
and "Puff", too
Fulltime
2019 Ram Longhorn
